Help with gear shift indicator
Old Oct 21, 2009 | 02:33 PM
casey007's Avatar
casey007
Default Help with gear shift indicator
Hello
I have an A4 and recently changed out the shift boot. When removing the old boot a couple of pieces went flying and I can't figure out how they go back in. I popped by the GM dealer and had there vette expert take a look and after 5 minutes he couldn't figure it out.
The piece I need to fit in, is the orange indicator plastic piece. I have tried every which way and can't figure out how it goes into the shift indicator housing.
Your help is appreciated.
Old Oct 21, 2009 | 02:42 PM
JEEP/C5's Avatar
JEEP/C5
See if this helps you.
http://www.VetteEssentials.com/instr...t_install.html
I had my shifter apart two months ago and my orange thing fell out (dont you hate it when that happens). I was able to put is back without a problem. Just take your time and you will get it.
Good luck.
