Power steering pump or rack?
Old Oct 22, 2009 | 07:40 AM
NOLAVette's Avatar
NOLAVette
Default Power steering pump or rack?
As I was turning left into the gas station to fill up, I noticed it the steering got pretty stiff. When I turned it back to the right it felt fine. Fluid level is fine with no leaks or noise. At first I thought it was probably the pump. But why would turning the steering wheel to the right work fine but not to the left? After reading this on the Zip Corvettes site I'm starting to think it may be the rack, and not the pump.
"If your Corvette is experiencing dead spots or grabbing in the steering until the fluid warms up, consider replacing the rack & pinion with a remanufactured unit"
Seems like the pump is working fine if I can turn the steering wheel to the right with no trouble, but not to the left. There seems to be only one output line on the pump-not a left and right output.
Other opinions?
Old Oct 22, 2009 | 09:36 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Yes, the pump only has one output line. Your problem sounds like a seal in the rack.
Old Oct 22, 2009 | 11:00 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Yea might be the rack.. that sucks, its not cheap to replace.
Old Oct 22, 2009 | 02:39 PM
NOLAVette's Avatar
NOLAVette
I found a couple of them (rebuilt) for about $200. Not too bad.
Old Oct 22, 2009 | 04:12 PM
Evers98's Avatar
Evers98
where did you find the "rebuilt" for $200 at? i have a blown seal in mine and have been looking around to find a new one.
Old Oct 22, 2009 | 04:24 PM
Mark C5's Avatar
Mark C5
Zip Products in Richmond, VA. You can only buy rebuilt or remanufactured units, new one's are no longer available to the best of my knowledge. I have one from Zip in my car now and have had it for a year and 20K miles with no problems.
Old Oct 22, 2009 | 04:33 PM
Evers98's Avatar
Evers98
sweet thanks ill check them out
Old Oct 22, 2009 | 05:38 PM
NOLAVette's Avatar
NOLAVette
Yep-that's it-Zip-corvette is where I found it.
I suppose I should go ahead and order it, then drag out the service manual.
Old Oct 22, 2009 | 06:25 PM
Mark C5's Avatar
Mark C5
Definitely follow the service manual procedure. All the people who have problems seem to be the one's looking for shortcuts. You also will want to pick up a set of these for the power steering pump lines:
Old Oct 22, 2009 | 07:47 PM
NOLAVette's Avatar
NOLAVette
I can't find that set online. Can you give me a model # or name of the wrench set?
Old Oct 22, 2009 | 07:53 PM
Mark C5's Avatar
Mark C5
I don't have the number for that set, it was just a pic I used to show what a crows foot is. If you do a Google search for "crows foot" you'll find a bunch of sets that will work just fine. I don't remember the size you need offhand, maybe someone can chime in. I'm thinking 18 MM but I could be wrong.
Old Oct 22, 2009 | 07:55 PM
NOLAVette's Avatar
NOLAVette
Sorry-Spoke too soon. I found a set for about $39 from Lee's Tools website.
To Power steering pump or rack?
