Anyone Using a Sequential Tailight Adaptor With LED Tailights???
Old Oct 24, 2009 | 02:26 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
You're the MAN!!!!!!!!!! Thanx a bunch! It looks pretty damn good!!
Tim
Old Oct 24, 2009 | 02:42 PM
GHL4505's Avatar
GHL4505
Yep! Mine work just like rpm462. About the same as when I had them with the stock taillights. A bit fast, but not bad at all.
Old Oct 24, 2009 | 02:46 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I think I'm going to order up one of those to go with these I just added
Old Oct 24, 2009 | 04:22 PM
JropTop's Avatar
JropTop
Originally Posted by rpm462
You being an azz? Tell me it's not so! Maybe this will help you, here's mine with the flashers on. Pardon the mess in the garage!
[IMG][/IMG]
HEY,wait a minute! My flashers go Bananas when i use them,almost like a bulb is out,but when I dont use them,everything works normal,brakes,taillights,directionals,et c......HMMMMMMMMMM,what could it be?
Old Oct 24, 2009 | 07:40 PM
tstar's Avatar
tstar
Thanx everyone for the info, video and confirmation... as always you guys always come through!!!!
Tony - What exactly do you have for exterior lighting now and any load equalizers, Hyperflash Harness ect... ???
Tim
Old Oct 24, 2009 | 10:49 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I have the bypass harness, sequencer, and LED tails and 3rd brake flasher. They work well. The only different thing I can add is your brake lights will also sequentially light along with the emergency flashers. First the inside then the outers.
Old Oct 25, 2009 | 12:39 AM
tstar's Avatar
tstar
You're like the devil... tempting me!
I mean
Tim
Old Oct 25, 2009 | 12:44 AM
JW Motorsports
Banned Scam/Spammer
me?
Old Oct 25, 2009 | 12:45 AM
tstar's Avatar
tstar
Now that's interesting, not a show stopper by any means though. I don't believe my sequentials do that, the brake signal passes through unaltered...
Tim
Old Oct 25, 2009 | 07:24 AM
JropTop's Avatar
JropTop
Tim
Ok bud,here it goes-I have the 48 led tower bulbs for my DRLs,led taillights with the sequential turn signals,8000k HID headlights and fog lights,and halogen 1156 reverse light bulbs.Ive experienced with load equalizers,resisitors for precautionary measures and they made my lights do some crazy things.I removed them and my lights work as they should only with the hyperflash relay installed!Now,they only thing i notice differently,and hadnt realized it till i saw the short clip on here on how the taillights blink when the hazards are on,is that mine blink rapidly as if i have a bulb out,not sure why,but other than that,all works great!Hope that helps!Another piece of info is that from 1997-2004 GM has altered a few things in the electrical dept,so what may not be compatible with early models and used the precaution of installing equalizers or resistors make work for them but may not work for the newer yrs!
Old Oct 25, 2009 | 07:40 AM
tstar's Avatar
tstar
Sent an Email... the Forum went down on me as I was answering ya...
Tim
Old Oct 25, 2009 | 07:45 AM
JropTop's Avatar
JropTop
Old Oct 27, 2009 | 09:57 PM
  #33
VRedZ06's Avatar
VRedZ06
St. Jude Donor '10
My C6 is fine no issues
Old Oct 28, 2009 | 03:49 AM
  #34
tstar's Avatar
tstar
Thanx!
Tim
Old Jan 31, 2010 | 09:20 PM
  #35
Aerovette's Avatar
Aerovette
Is there a way to sequence the LEDS across the inside lens and then continue the sequence on the outer lens? All of these have both lenses sequencing together.
Old Jan 31, 2010 | 09:31 PM
  #36
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
working on a solution. The problem is the standard GM flash rate of about 80fps is just too quick for any 6-stage sequencer i've come across.
Old Jan 31, 2010 | 10:58 PM
  #37
tbrent's Avatar
tbrent
2018 C5 of Year Winner
for your undying efforts!
