Rear Hatch
Oct 24, 2009 | 04:36 PM
Rear Hatch
Is there a way to adjust the rear hatch? There is a slight difference on how far it shuts from the left side to the right side.
Cant figure out if there is a way...thx
Oct 24, 2009 | 06:42 PM
St. Jude Donor '08
Quote:
Originally Posted by
jfattizzi
Yes.
Pull of the rear covers and you'll see the adjustment bolt (10mm) that allows you to adjust the latches.
Oct 24, 2009 | 10:08 PM
Good info. Saving this tip for possible future use.
Oct 24, 2009 | 11:43 PM
What rear covers? what is that?
Dec 13, 2009 | 09:07 AM
Can anyone expand on how to do this?
Dec 13, 2009 | 09:12 AM
St. Jude Donor '08
jfattizzi
The covers on the back where your top goes at the rear of the trunk.
Dec 13, 2009 | 09:14 AM
I dont have the convertible.....I have the coupe. Can I still adjust the rear hatch?
Dec 13, 2009 | 09:18 AM
St. Jude Donor '08
jfattizzi
Yes
Dec 13, 2009 | 09:20 AM
Dec 13, 2009 | 09:22 AM
St. Jude Donor '08
jfattizzi
How?
Go open your hatch.
Pull the rear covers off of the back wall and you'll see the locking mechanism..
Use a 10mm to loosen the adjuster bolts and adjust as needed.
Dec 13, 2009 | 09:23 AM
What are the covers? sorry
Dec 13, 2009 | 09:26 AM
St. Jude Donor '08
jfattizzi
Go open your trunk and look straight down. There are covers against the rear were the weatherstriping is lcoated.
Remove them and you'll be abe to adjust the cargo hatch.
Dec 13, 2009 | 09:27 AM
Dec 13, 2009 | 09:28 AM
St. Jude Donor '08
jfattizzi
thank you
No problem
jfattizzi
The protrusions that your top would lean on when stored back there.
