Headers on...start but no run..help
Old Oct 25, 2009 | 06:39 PM
Gunnrunner's Avatar
Gunnrunner
Default Headers on...start but no run..help
So here's the situation. Finally installed the headers and go to start the car, it starts right up then dies. Let me tell you how the O2's are set up. This may be the issue. I used the rears in the front locations with flat to square adapters. Right to right, left to left, just like stock. The rear plugs are left open. Do I need O2 simulators for this to run? It's going to the dyno and they will tune them out so I thought no problem to leave them open...incorrect thinking, I'm thinking...Please get me straight !!!
Old Oct 25, 2009 | 06:45 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
What all did you take out/apart?
It should run without the rears. I don't have any of mine plugged in I just have the holes plugged. You will get codes until they clear them though.
Old Oct 25, 2009 | 07:02 PM
89vert's Avatar
89vert
I'm not sure where to start. I'm thinking of the last set of headers I helped put on.
It should run with out the O2 sensors. After all it did run and then died.
Does it still turn over but won't start?
Did you disconnect the fuel line?
Did you remove the coil packs?
Anything you disconnected I would double check.
If I were closer I would come over and help check things out.
Old Oct 25, 2009 | 07:05 PM
Gunnrunner's Avatar
Gunnrunner
Far as I know we swapped the rear O2's for the fronts and used the adapters to go from square to flat. We left the rears open, just tied up out of the way. It's crazy, the car fires right up and 5 sec later....dies. That's why we were thinking we need O2 sim's to fill in the rear plugs.
Old Oct 25, 2009 | 07:19 PM
89vert's Avatar
89vert
Any codes besides the rear O2 codes?
Old Oct 25, 2009 | 07:42 PM
Gunnrunner's Avatar
Gunnrunner
I have no idea if it has thrown a code..won't run long long enough to see a check engine light, and I dont have an OBD2. Just trying to get it to run so we can get it to the dyno. One of the FAQ's in the header install thread @ LS1 how to said you will need O2 sims. We removed the coil paks, no fuel, starts instantly..then craps out....
Old Oct 25, 2009 | 07:47 PM
Chevy Guy's Avatar
Chevy Guy
Cank you have the front O2's crossed??
The rear O2's are reference for the cats only they do not effect the way the car runs. I drove my car for months w/ no O2's after the header install and prior to my tune.
Old Oct 25, 2009 | 07:55 PM
Gunnrunner's Avatar
Gunnrunner
Chevy Guy,
My friend took it apart but from what I recall, where the front O2 were located, they are not long enough to go to the opposite side. I could rewire them opposite, but I don't understand. Am I missing a piece of the puzzle? Obviously !!!
Old Oct 25, 2009 | 07:59 PM
Chevy Guy's Avatar
Chevy Guy
Originally Posted by Gunnrunner
Chevy Guy,
Yeah, its coming back to me now. I just pulled out my LG paper work and checked as well.
Take a little break and clear your head. Go do something else for a while and go back to the car and start checking everything you touched for loose connectors. Maybe a vacuum hose got knocked loose?
Old Oct 25, 2009 | 08:12 PM
BanditDude's Avatar
BanditDude
You don't need an ODBII scanner, as you already have one built-in. Use this procedure to check the codes. I agree that a rear O2 will not this problem, as I've been driving mine without 'em for over a year...just resetting codes thru the DIC.
Of the things I can think of, you might want to double-check:
  • coil pack connections
  • the driver's side engine ground that was removed
  • for a massive vacuum
  • front O2 connections
Old Oct 25, 2009 | 08:37 PM
Gunnrunner's Avatar
Gunnrunner
BanditDude,
Am i correct for the front O2's left,left/right/right? The driver side engine ground was installed in a different place but my friend says the path should be the same.
Old Oct 25, 2009 | 09:56 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Did you do a mail order tune by chance?
If so you might have to relearn the computer.
the process for this is to try and start car, it will die on you leave key on till security light goes off. Do this two more times then on the third it should start and stay running.
Thats what i had to do when i reinstalled my new computer. It actd the same. it fired right off then died.
Old Oct 25, 2009 | 10:00 PM
cruisemon's Avatar
cruisemon
I think the front O2's are wired left connector to right O2 and right connector to left O2. I'll get up under my car and check. Maybe someone else can step in and confirm if this is correct or not.
Charlie
Old Oct 25, 2009 | 10:06 PM
BanditDude's Avatar
BanditDude
BanditDude,
Yes. The front O2's remain on their own sides.
I agree that a different mounting point for the ground should not be an issue. It just needs a strong path.
Old Oct 25, 2009 | 10:08 PM
IDM's Avatar
IDM
why did you mess with any o2 sensors thats your problem for sure put that back to stock, reset your ecu and try again
never heard of a problem with the car not idling after a long tube install
Old Oct 26, 2009 | 07:43 AM
Chevy Guy's Avatar
Chevy Guy
Thats the process for most long tubes. LG wants you to leave the rears out and use them for the front w/ adapters.
This has to be something silly. It actually sounds like the security system is killing the car.
Do you have another key to try?
Old Oct 28, 2009 | 07:19 AM
Chevy Guy's Avatar
Chevy Guy
Did you find anything?
Old Oct 28, 2009 | 08:19 AM
0Double D Mods
Former Vendor
It was a ground wire
To Headers on...start but no run..help
