Sun visor LED Bulbs?
Old Oct 27, 2009 | 12:34 AM
IDM's Avatar
IDM
Default Sun visor LED Bulbs?
I haven't heard of anyone replacing these. The stock ones are yellow.
And no please don't say it's because the LED will blind you lol, this is just for a show car.
Old Oct 27, 2009 | 12:43 AM
SilverC54me's Avatar
SilverC54me
I have looked into doing this. The bulbs that are in there are not easily removable.
You almost have to tear apart the visor to do a proper job of installing LED's here. I may do this if I have the visors redone.
Gary
Old Oct 27, 2009 | 03:48 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Damn!!! And here I thought I replaced all the bulbs... forgot about these!
I don't even know what bulbs are in there... but I'm sure we can come up with a solution!
Old Oct 27, 2009 | 04:48 AM
If anyone has done it, it would be The Radioflyer. Might check with him.
Old Oct 27, 2009 | 01:01 PM
IDM's Avatar
IDM
Tim,
I forgot too, I was getting my interior projects cleaned up for you know what and saw the nasty yellow.
The information above is incorrect.
I did the mod today. By the time I got to the 2nd bulb on the first sun visor it was taking me 15 seconds to change them out.
They are P 37 bulbs. You take off the cover with a tiny flathead. Use a pick to take out the bulbs and pop on the new LED and cover.
All done
Old Oct 27, 2009 | 01:48 PM
97c5vette's Avatar
97c5vette
where do you guys buy p 37 led bulbs?
Old Oct 27, 2009 | 04:55 PM
tstar's Avatar
tstar
Try here;
http://autolumination.com/74.htm
Best bet is to remove one and match it up with the pics on that webpage.
Tim
Old Oct 27, 2009 | 04:58 PM
tstar's Avatar
tstar
Originally Posted by IDM
Tim,
All done
That's odd, Gary is usually spot on! I wonder if there were some model year changes???
At any rate, which 37 did you end up using? I'm out in the sticks and have to order all my stuff and usually use autolumination.com for LED bulbs. If you have a minute peruse the link above and let me know which ones fit the best...
Thanx....
Tim
Old Oct 27, 2009 | 05:55 PM
IDM's Avatar
IDM
It could be different sun visors I think somethings are different about them I remember
Umm I looked on that fancy website. I'd say the first ones that are 2.50 look most like mine.
The problem is that I didnt order these, I had them extra from another car and they happened to work or Id just tell you where I ordered them from.
Mine probably dont work best as possible, they are just a general led that fit in there.
You dont want the light going straight out from the tip of the LED. You want it going out on the half that will put light out towards you. best to take one of yours out with a pick and make sure
Sorry I suck so bad Tim
Old Oct 27, 2009 | 06:09 PM
tstar's Avatar
tstar
You don't suck!
Goofball....
I'll post back in here what I find out!
Tim
Old Dec 18, 2010 | 10:39 PM
_zebra's Avatar
_zebra
well... did you ever find out? i'm looking to swap to LEDs in the visors of my 2000
Old Dec 18, 2010 | 10:59 PM
IDM's Avatar
IDM
just read through the thread
Old Dec 18, 2010 | 11:23 PM
_zebra's Avatar
_zebra
i did read it & the page you linked had a whole slew of different bulbs & somebody said they'd post up which exact ones it ended up being
Old Dec 18, 2010 | 11:26 PM
IDM's Avatar
IDM
sorry I wish I could help more I had these bulbs sent to me for another car and when they wouldnt work for my application I tried them in there and got lucky.
Old Dec 19, 2010 | 05:16 AM
tstar's Avatar
tstar
Pull your bulbs, then compare em to the ones in here;
Maybe the fourth ones down titled;
"Introducing the Matrix II 5 led 5x brighter than than conventional single #74 leds
5x leds emit light in all directions Bulbs are 3/4" (22mm) x 1/4 (7mm)" diameter at widest point with T5mm base to fit standard #74 or #37 sockets."
Tim
Old Dec 19, 2010 | 08:39 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I want these too!
Have we found any yet?
Subscribing
Thanks,Matt
Old Dec 24, 2010 | 07:25 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I am researching LED bulbs for various points in my car.
I took the rear view mirror apart. There is a board inside there with 9 LED's mounted to a board, and a pig tail connecting the board to power. Passenger and drivers side each have one. The LED's are mounted 3x3 on the board. It was a PAIN to get back in there right too. I don't see anything like this on the LED sites. I think you would have to replace/solder the actual LED's on the board if you wanted to change this. There are 6x Amber LED's, and 3x White LEDs on each side (drivers/pass).
Toque
Old Dec 24, 2010 | 08:04 PM
SilverC54me
Toque
You have to remove the LEDs from the board and replace them with the color LED you want. See the big 'New LED mod' thread for further information.
Gary
To Sun visor LED Bulbs?
