P0420-Catalytic Converter-HELP Please
Old Oct 27, 2009 | 04:39 PM
sbontrag@hotmail.com's Avatar
Default P0420-Catalytic Converter-HELP Please
I also have a post on the Vararam issue but now a different (?) issue. The issue from last week was DTCs P0171 & P0174 which was the long term fuel trim which was supposed to be corrected my moving the MAF sensor back to its original position. With the Vararam modifications it was moved next to the throttle body. Now the P0420 code is displayed. The freeze frame data is shown below:
Control Module
$10 SAE J1850 VPW
Stored Codes
P0420 Catalyst System Efficiency Below Threshold Bank 1
Control Module
$10 SAE J1850 VPW
View Freeze Frame
DTCFRZF P0420
FUELSYS1 OL-Drive
FUELSYS2 OL-Drive
LOAD_PCT(%) 2.0
ETC(¡æ) 180
SHRTFT1(%) 0.0
LONGFT1(%) 12.5
SHRTFT2(%) 0.0
LONGFT2(%) 12.5
MAP(kPa) 11.2
RPM(/min) 563
VSS(km/h) 0
MAF(g/s) 0.741
TP(%) 3.9
Control Module
$10 SAE J1850 VPW
Since DTCs Cleared
MIL Status ON
Misfire Monitor OK
Fuel System Mon OK
Comp. Component OK
Catalyst Mon OK
Htd Catalyst N/A
Evap System Mon OK
Sec Air System OK
A/C Refrig Mon N/A
Oxygen Sens Mon OK
Oxygen Sens Htr OK
EGR System N/A
Any help or ideas are greatly apprciated. Thanks!
Old Oct 27, 2009 | 11:28 PM
Brian@FI Performance's Avatar
0Brian@FI Performance
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
Are you running cats?
Brian
Old Oct 28, 2009 | 05:55 AM
Default Cats
Yes, they look like B & B by the pipe connection to resonator. They were on the car when I purchased it.
Old Oct 28, 2009 | 01:20 PM
ysb02's Avatar
ysb02
Aftermarket cats will trigger 420 and 430 iirc. You'll need o2 sims or turn the DTCs off with an ECU editor.
Old Oct 28, 2009 | 08:03 PM
Default P0420
AZ has a biannual emissions check through the OBDII. Will sims or modifying the ECU cause a failure??
Old Oct 28, 2009 | 09:27 PM
Former Vendor
I can not comment for AZ, but we are similar in CT. When emissions plugs into us, they are looking for to see if there are any emissions related CELs and to confirm the 02 sensors are in "ready" status...
Old Oct 29, 2009 | 02:59 AM
did you do the Sims or reprogram ECU?
Old Oct 29, 2009 | 11:55 AM
Former Vendor
Tune
Old Nov 7, 2009 | 05:19 PM
Do you have any knowledge of the Hypertech tune and whether that will work in this situation? Thanks
Old Nov 7, 2009 | 11:18 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Originally Posted by Brian@FI Performance
Tune
Hypertech and Predator handheld tuners will not do the trick. You need a professional tune done and edit the computer... delete out the rear 02's. You have aftermarket cats that are probably hi-flow that is the cause of the code.
Old Nov 8, 2009 | 05:40 PM
Thank you. i will look for a shop that does Corvette tuning. It has got to be cheaper then to keep replacing items on the car!
To P0420-Catalytic Converter-HELP Please
