99 C5 Key Fob
Old Oct 29, 2009 | 07:33 PM
raymondh's Avatar
raymondh
Default 99 C5 Key Fob
Anyone know where to pick one up real cheap? Also, does anyone know the GM part number? Thanks in advance.
raymondh's Avatar
raymondh
Guess I should have said Keyless Entry FOB
Old Oct 29, 2009 | 08:44 PM
TheDingo's Avatar
TheDingo
Unfortunately, I think you'll have to go to the dealer for that one.
Old Oct 29, 2009 | 08:52 PM
SaberD's Avatar
SaberD
Gene Culley! gmpartshouse.com. he has specials on key fobs almost every month. the early key fobs with the passive feature are MUCH more expensive, but the newer fobs without it are pretty cheap and will still work for your car. i spent the extra cash and got the one with passive jsut cuz i think its cool.
Old Oct 29, 2009 | 09:20 PM
RDS_VETTE's Avatar
RDS_VETTE
GM Part number for 1999 is: 10253839
Got mine at the local GM dealer for $85 and they programmed it. Neither of the 2 that came with the car worked even after changing batteries and reprogramming.
At gmpartshouse.com it is $74.
http://www.gmpartshouseusa.com/partl...&siteid=214638
Hope this helps.
Old Oct 30, 2009 | 01:44 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree. Gene Culley is the man to get it from.
Old Oct 30, 2009 | 06:26 AM
65GGvert's Avatar
65GGvert
The newer cheaper ones will NOT work with your car. The 2000 fob without passive will work with your car, but is not any cheaper. Choose whether you want passive or not (98/99 with, 2000 w/o) and call Gene Culley. Don't bother buying a used one, you'll end up with the same problem shortly.
Old Oct 30, 2009 | 08:49 AM
raymondh's Avatar
raymondh
Yes, I have the passive feature, although I'm not really sure what that means?
Old Oct 30, 2009 | 08:50 AM
raymondh's Avatar
raymondh
Thanks for all of the replies!
Old Oct 30, 2009 | 09:01 AM
davek 515's Avatar
davek 515
Gene's the man!
Old Oct 30, 2009 | 10:04 AM
raymondh's Avatar
raymondh
Wow, talk about a great resource. I used the soldering technique discussed in how to repair your key fob and it worked. Now, I have two key fobs that work and only spent $5.00 bucks on batteries which I didn't even need. This forum is the greatest!. Thanks for sharing your knowledge and experience everyone!
To 99 C5 Key Fob
