[Z06] LT Headers- Reasonable HP Expectations?
Old 10-30-2009, 12:09 PM
NatB
NatB's Avatar
Default LT Headers- Reasonable HP Expectations?
I have a 2002 Z06 which EnglandGreen recently dyno tuned at 374RWHP. The only mods were as follows: CAI Intake (homemade with KN Filter); Magnaflow X-Pipe; and Corsa Extreme Cat Back System.
Stephen and Jason both indicated that I had a fairly healthy basically stock Z06 to yield the 374 RWHP.
I am contemplating having LT Header (with Cats) installed by EnglandGreen and having them re-run the dyno tune.
With 374RWHP already - What can I realistically expect ( no BS) to gain in RWHP with the addition of a LT Header system?
I am guessing 385 RWHP - Obviously for the dollars being spent I would prefer to see 390RWHP plus.
Anyone ?
Old 10-30-2009, 01:39 PM
0EG@EnglandGreen
Supporting Tuner
Support Corvetteforum!
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
My guess is around 385rwhp, possibly even 390rwhp. The highest we have seen on a bone stock Z06 with CAI & full exhaust through the Ti catback is 395rwhp on a Dynojet 248x.
Stephen
Old 10-30-2009, 02:12 PM
wildbill ws6/ss
wildbill ws6/ss's Avatar
I did 375 with intake and tune only....Just did longtubes..xpipe no cats and retune through stock ti catback..did 390/371. My car I belive is also a tad stronger than most
Old 10-30-2009, 07:28 PM
HWY HNTR
HWY HNTR's Avatar
Def worth it.
Old 10-30-2009, 07:51 PM
TheDingo
TheDingo's Avatar
I was under the impression that you could easily get 20whp with long tubes.
Old 10-31-2009, 01:05 AM
ctusser
ctusser's Avatar
Long tubes in themselves only contribute around 15hp to these cars on a stock engined bolt-on car. If you are doing the install and tune yourself it might be worth the cost IMO. But if you are farming it out you must ask yourself is $1,200-$1,500 for the headers + install and re-tune.
Depending on where you are doing it you could be well over $2K for 15hp. Might be good for a tenth or two in the 1/4 mile. If it seems worth it to you that's your call.
Old 10-31-2009, 01:46 AM
TheDingo
TheDingo's Avatar
that's true but if you plan to do anything to your car other than an intake and a catback, long tubes are really where you want to begin..
Old 10-31-2009, 08:11 AM
Its Bruce
Its Bruce's Avatar
I made 383.3 w/ ARH LTs and CAI @ EG but I have no stock baseline numbers to compare it to.
Old 10-31-2009, 08:37 AM
Rob 2K1
Rob 2K1's Avatar
I made 393 with LG Pro's /w cats & Blackwing through the Ti's. I would think 15-20hp is reasonable with the addition of long tubes and new tune.
Old 10-31-2009, 10:32 AM
Its Bruce
Its Bruce's Avatar
Stephen, find me some more powa!
Old 10-31-2009, 11:55 AM
DD04C5
DD04C5's Avatar
If you go with the LG Pro's and high flows at least 20 HP.
Old 10-31-2009, 11:57 AM
JimbeauZ06
JimbeauZ06's Avatar
My 2001 Z baseline dyno run with stock everything except K&N filter in the stock box was 331rwhp. With Blackwing, CF bridge, LG Pro LTs & tune she bumped to 380rwhp. Everything else still stock including Ti exhaust.
Old 10-31-2009, 12:41 PM
C5Z
C5Z's Avatar
An 01 will respond a bit better to bolt-ons than an 02+ b/c the factory airbox and pup cats were restrictions that were changed for 02 to help increase the output.
Old 10-31-2009, 05:43 PM
NatB
NatB's Avatar
Thanks everyone for responding to my post !
I am figuring LT Headers with cats ( either LG Pros or American Racing) will bump my present 374 RWHP to the range of 380 to 390 RWHP - likely around 385 RWHP.
On the high end- it sounds like 390 to 394 RWHP is possible while maintaining a safe tune.
Old 10-31-2009, 06:25 PM
DARRYLZO6
DARRYLZO6's Avatar
Sounds pretty healthy but I would discount the cat-back exhaust because the gains there are pretty minimal. Long tubes would probably bump it up about 10-15hp. The stock TI is less restrictive than people think. My 01Z has Blackwing, modified radiator shroud, Vram power duct,Stainless works headers, high flow cats , X-pipe and tune for 392hp-387lbsft. Im all good!!
Old 11-01-2009, 12:52 AM
ctusser
ctusser's Avatar
I'd change the cam at the same time to get a power increase that's noticeable. Re tunes after every little mod must add up unless they give big price cuts on the adjustments for repeat business.
Old 11-01-2009, 09:41 AM
wildbill ws6/ss
screw tha cats man.
To LT Headers- Reasonable HP Expectations?
Old 11-01-2009, 02:17 PM
NatB
NatB's Avatar
Originally Posted by wildbill ws6/ss
screw tha cats man.
In Houston you get a fine for not running cats- I know people who've been pulled over and the LEO checked underneath for cats. Serious fine I think.
Regardless- the cats are there to reduce the pollution my kids are going to have to deal for years to come. I'm sticking with them
Old 11-01-2009, 03:00 PM
rbartick
rbartick's Avatar
Location: Admit Nothing, Deny Everything, Make Counter Accusations.
In addition, removing hi-flow cats will not yield a sigificant increase in performance. I'd leave them in.
Old 11-01-2009, 05:47 PM
JimbeauZ06
JimbeauZ06's Avatar
There was an article comparing LG Pro-series with and without hi-flo cats. No reason not to have them unless it's a track only car.
Corvette Fever or one of those.
Quick Reply: [Z06] LT Headers- Reasonable HP Expectations?
