Creative Engine Covers/ catch can question
Old Nov 1, 2009 | 11:40 PM
Bill Vett's Avatar
Bill Vett
Default Creative Engine Covers/ catch can question
Does anyone have a Creative Engine Covers idler pulley cover and know if you can still have a catch can? Thanks for any info. Bill
Old Nov 2, 2009 | 12:24 AM
dobewillie's Avatar
dobewillie
Give Chip at CCA a shout he probably can let you know
Old Nov 2, 2009 | 06:13 PM
FRED HAMBLE's Avatar
FRED HAMBLE
YES IT IS TIGHT BUT DO ABLE. I have the pully cover and a catch can. I needed to put a 1/2" spacer to bring the catch can out to clear the cover.
FRED
Old Nov 2, 2009 | 07:54 PM
Bill Vett's Avatar
Bill Vett
Thanks Fred, With out the cover or the catch can I wasn't sure. Now I can order both. Again... THANKS!!! Bill
Old Nov 3, 2009 | 08:12 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
FRED
Correct, a half inch spacer or bend the bottom of the BTC about 20 degrees (for a CCA Can)
Peace
Chip
__________________
..................Click for
Old Nov 3, 2009 | 01:20 PM
Bill Vett's Avatar
Bill Vett
Thanks Chip
Old Nov 3, 2009 | 06:21 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Or,,, you could relocate the catch can to a spot in front of the radiator.
Theory has it that the cooler the catch can is the better it will work. I believe your only issue is making sure the lines to the catch can from the engine don't travel uphill. Going back to the engine it doesn't matter.
Someone will correct me if I'm wrong....
Old Nov 3, 2009 | 08:54 PM
CCA Corvette Parts
100% correct
Peace
Chip
Old Nov 17, 2009 | 03:27 PM
Bill Vett's Avatar
Bill Vett
Thanks everyone it was easy once I had everything together. All I needed was a small spacer the size of the bracket to do the lower nut and bolt on the cover. I need to find a 45* or a 90* fitting for the one that returns to the throttle body. I guess an auto store or Lowe's?????
Note slight kink in hose....Once I get the fitting I'll do braided hoses.
Old Nov 17, 2009 | 06:34 PM
FRED HAMBLE
Nice job !!!
Where did u get your caps from? Are they Chrome?
Fred
Old Nov 17, 2009 | 07:02 PM
Bill Vett's Avatar
Bill Vett
Yes they're chrome, got them from a Forum vendor and a great price...
http://www.shop.djmotorsportaccessor...1&categoryId=1
Old Nov 17, 2009 | 07:54 PM
FRED HAMBLE
Thanks for the info.
FRED
To Creative Engine Covers/ catch can question
