Oil Level sensor location
Old Nov 2, 2009 | 08:31 AM
VinnyT's Avatar
VinnyT
Default Oil Level sensor location
Did a search, saw nothing. Where is this sucker located? Mine needs replacement.
Old Nov 2, 2009 | 09:10 AM
Dominic Toretto's Avatar
Dominic Toretto
Good question. Are you getting a code that lets you know it needs replacing?
-Alex
Old Nov 2, 2009 | 09:14 AM
VinnyT's Avatar
VinnyT
Haven't check codes, DIC showing "Low Oil Level". Added more oil, reset, but still showing message.
Old Nov 2, 2009 | 09:19 AM
VinnyT's Avatar
VinnyT
Originally Posted by 8VETTE7
Back of the oil pan, passenger side. You will need to drain the oil first so might as well do an oil and filter change. Check the electrical connector before you change it. It might be loose or damaged.
Thank you!!
To Oil Level sensor location
