[Z06] Spark Plug Gap
Old Nov 3, 2009 | 12:59 PM
Paul 75 L82's Avatar
Paul 75 L82
Default Spark Plug Gap
I going to install a new set of Iriduum plugs in my 02 Z06. Does someone know the plug gap?
Old Nov 3, 2009 | 02:18 PM
Melsy's Avatar
Melsy
Paul;
There was a TSB about a new plug for our cars as well as other GM cars. The Delco iridium plug is pre-gapped. Don't mess with it. The new plug is AC-Delco 41-985. Hope this helps.
Old Nov 3, 2009 | 02:26 PM
Zo3o6's Avatar
Zo3o6
.060 on my `03... should be the same as the `02.
Old Nov 3, 2009 | 04:22 PM
Paul 75 L82
I bought the 41-110. I got that number from the forum. Is that plug pre-gapped?
Old Nov 3, 2009 | 09:04 PM
Zo3o6's Avatar
Zo3o6
Check the gap to make sure, You can buy a gapper at any
Auto part store.... 99 cents...
I put some ngk`s in.... they were gapped at .040
You can gap the plugs when their new, but not after being run.
Ron
Old Nov 4, 2009 | 12:31 AM
James92's Avatar
James92
I bought the AC Delco Iridium's 41-985 and I gapped them at .055". Bigger gap, bigger spark. Just did mine 3 weeks ago, I drive the car every day and it runs perfect.
Old Nov 4, 2009 | 09:25 AM
CSM Z06's Avatar
CSM Z06
The AC/Delco service bulletin 03D-J-171 reads "A new spark plug has been released for use in the above vehicles.(Corvette 97-04) The new spark plug has an
Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the
spark plug has also changed. The new spark plug, ACDelco Part Number 41-985 (12571164), is
gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during
manufacturing and should not be changed to the gap required with the Platinum plug, or damage
to the spark plug may result."
But this isn't really new as the bulletin is dated DEC 12, 2003
Old Nov 5, 2009 | 09:12 PM
tlc0706's Avatar
tlc0706
I would never put a plug in my car without checking the gap....just be careful with the new ones...
Old Nov 5, 2009 | 11:42 PM
pcbunn's Avatar
pcbunn
Check the spark plug box, it will most likely tell you that the gap is pre- set and not to try to change it or risk damage to the plug.
To Spark Plug Gap
