Winter storeage
Old Nov 6, 2009 | 04:55 AM
VITIV Coupe's Avatar
VITIV Coupe
Default Winter storeage
Well it's that time of year again. I have searched previous threads here and could'nt find any information regarding this subject. My question is, can I take the battery out of the car for the winter? Would there be any harm in doing this because of all the computer accessories. I usually take the battery out of my HD Ultra-Classic and no harm but it only has a mini-computer.
I have a battery tender, but I would just like to know if there is any harm in taking the battery out of the car for 5 months.
Thanks in advance.
Smokey.
Old Nov 6, 2009 | 05:20 AM
PierEagle's Avatar
PierEagle
Should not be a problem. You would have to reset your "memories" when you put the battery back in. Do not store the battery on the ground or concrete floor. Set it on a wooden board and hook a charger to it, about once a month to keep it from sulfating. Whether you use a charger or maintainer and don't have a maintenance free battery, be sure to check the water level about once a month.
Personally, I would leave the battery in, with a maintainer. About once a month I would start the car and let it run for awhile, turning on the a/c and then the heater, to get fluids circulating and prevent seals from drying out.
Old Nov 6, 2009 | 06:15 AM
VITIV Coupe
Thanks for the reply. I have an attached 2 car garage and I back the car in so I can get out of the car but that makes the battery on the opposite side (too close to the wall to get access for the battery tender hook-up). If I were to put the battery tender on the battery in the car, where do you route the wires with the car cover on?
One last question, I have had the column lock recall performed and by taking the battery out, it will not erase this recall and when I put it back in I just hope I don't have the colum lock issue again.
Thanks,
Smokey.
Old Nov 6, 2009 | 06:21 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
It won't hurt to remove the battery. Several of my friends use a battery tender. I've been storing my car for 9 years now and just disconnect the negative terminal. It always fires right up in the spring. I also fill the gas tank and add Stabil, change the oil, over inflate the tires, and put several bars of Irish Spring soap and fabric softener sheets in the passenger and engine compartments. I then cover it and forget about it for the next 5 1/2 months.
Old Nov 6, 2009 | 06:56 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I've been doing the "winter storage" thing on various cars since the late 70s. I've usually don't remove, or for that matter, disconnect the battery. In the case of my C-5, which, as we all know, has enough computer power to launce an Atlas rocket, I simply throw the battery charger on it for 10 minutes every week, and every 2-3 weeks, I start it up and let it run for 10-15 minutes with the defroster on, so it cycles the A/C. I also drain the 10w30 oil out of it after the last ride in the fall, and put 0w20 in it for easier cranking in the winter.
I kept the worn-out run flat tires on the OE wheels, and also put them back on the car for the winter too. It may be silly, but even with the old tires, I still put a couple of pieces of old carpet under them for the winter.
Old Nov 6, 2009 | 06:59 AM
Tigershark3's Avatar
Tigershark3
I've stopped using stable and really the whole winterization thing. There may be 2-3 week periods where I won't take my car out from say December through March but if the roads are dry I drive it whenever I can. I do keep the battery on a maintainer but have never unhooked the battery. If you do this be very careful - these tires are not cold weather tires and will not hook up worth a crap. $.02
Old Nov 6, 2009 | 02:12 PM
Yes, you can take the battery out of the car - just remember that if you have the theft lock on the radio set, you will need to remember the code to unlock it when you reinstall the battery.
I just leave the battery in my car and hook up a Battery Tender Plus to it. Never had a problem.
If you would like some additional info on putting the car away for the winter, I have several Word files that might help you out. If interested, PM me your e-mail address.
Old Nov 7, 2009 | 01:42 AM
PierEagle's Avatar
PierEagle
I hook up the maintainer (mine is small enough to sit in the engine bay) and drop the connecting cord to the floor, by the radiator and run an extension to it. You can close the hood and cover the car. I also loosely tie a plastic newspaper wrap to the steering wheel to remind me, not to start the car with the maintainer hooked up and to unplug/move the cord.
Old Nov 7, 2009 | 05:46 AM
VITIV Coupe
Thanks guys for the replies. It gets pretty cold up here sometimes and goes below freezing in my garage so I think I'm going to remove the battery and take it in the house for the winter and put it on charge once a month. If I left it in the car and put the tender on it I'd hate to see that battery freeze up out there some nite.
Smokey.
Old Nov 7, 2009 | 07:42 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Thanks,
Smokey.
Back the car into the garage instead of driving it in forward would that help?I have my car cover up all the way with two covers and i bring the wires from the battery tender up throught the engine of the car nearest the battery.
Old Nov 7, 2009 | 07:53 AM
VITIV Coupe
If I back the car in, that would make my battery on the opposite side and too close to the wall to get at. I have to keep the car over against that wall so I can use the side door to the house.
Old Nov 7, 2009 | 09:11 AM
C7LOU's Avatar
C7LOU
I back my car in, too, and have enough room to squeeze in and hook up the battery tender. Even with the mirror folded in I can't get too close to the side wall to the point that I can't get in there. I just run the wires out the bottom of the engine bay and out behind the front tire and plug the tender in.
Old Nov 7, 2009 | 11:03 AM
Black-Sheep's Avatar
Black-Sheep
You can get a charger/maintainer with the cig lighter plug. That is how I have mine done. There is a nice "trough" at the bottom of the door to run the wire out of. There is no kink in it. I can slide it back and forth with the door shut so I know it isn't crimped. If you would do that, you could plug it in on the drivers side.
Old Nov 7, 2009 | 11:39 AM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Egor01 - as most have said, you can take your battery out of the car if you want. However, if you are only concerned about it freezing, I suggest you have nothing to worry about. I leave my truck outside all winter and don't plug it in. it starts just fine even when the temp gets down in the -30C range. It would just be a lot eaiser to plug the tender in and leave it until that beautiful spring day when you get to take it out of storage My baby is getting ready for its third year of storage in a non-heated garage for what its worth. Seafoam in the gas tank, extra air in the tires and the battery tender = easy start up in the spring.
on a side note, I would suggest NOT starting the car intermitently through out the winter unless you take it for a drive. letting the car idle in the garage for a few minutes is going to do nothing but build up condensation which is a bad thing. If you can't bring it up to operating temp, don't start it
Old Nov 7, 2009 | 04:01 PM
leadfoot4's Avatar
leadfoot4
Originally Posted by 00 Rooster
.....On a side note, I would suggest NOT starting the car intermitently through out the winter unless you take it for a drive. letting the car idle in the garage for a few minutes is going to do nothing but build up condensation which is a bad thing. If you can't bring it up to operating temp, don't start it
This debate countiues on......
I, for one, don't like leaving the valve springs compressed in one position for several months at a time. I also don't like to see some of the gaskets/seals potentially dry up due to lack of lubrication. Therefore, I start the engine an let it come up to temperature. I also like to get the A/C compressor turning and circulating the lubricant through the system. BUT everybody has their own methods....
Old Nov 12, 2009 | 07:29 AM
VITIV Coupe
Ok, I finally worked it out. I put the sta-bil in the tank, filled er up, backed the car in the garage (up on wooden blocks), unlocked the top and left it loose, hooked up the battery tender and ran the wires under the car and up thru the engine bay, closed the hood, put the cover on and she's good till April.
Smokey.
Old Nov 16, 2009 | 09:52 AM
charlene's Avatar
charlene
Smokey.
You got it good job charlene
To Winter storeage
Old Nov 17, 2009 | 11:26 AM
Jims2001's Avatar
Jims2001
I take my battery out every winter and have never lost any info. radio, computer, memories nothing.
Old Dec 3, 2009 | 12:43 PM
ovrpar6's Avatar
ovrpar6
I don't get it why soap and fabric softener?
Old Dec 3, 2009 | 01:09 PM
TraceZ's Avatar
TraceZ
I noticed that the other day. I had the battery out for a few hours and when I put it back in everything was still "remembered". I hit the memory #1 and my settings were all still there. Pretty odd, I thought.
