Removing paint from dash?
Old Nov 6, 2009 | 09:47 AM
aawil's Avatar
aawil
Default Removing paint from dash?
Recently got a 97 C5 and the previous owner seems to have taken a touch-up brush to the passenger side corvette letters. The worst part is he was a little sloppy in his application. Any suggestions as to what to use to remove it without messing up the plastic?
Old Nov 6, 2009 | 09:59 AM
bucwheat's Avatar
bucwheat
Try laquer thinner on a soft cloth.
Old Nov 6, 2009 | 10:09 AM
aawil's Avatar
aawil
Thanks I'll give it a try tonight
Old Nov 6, 2009 | 11:42 AM
Bill Vett's Avatar
Bill Vett
I'd try some paint thinner first on a place that doesn't show to see if any damage is done, if it looks ok then give the paint a try, I'm not sure that lacquer thinner will be good on the vinyl.
Old Nov 6, 2009 | 11:48 AM
dwspas's Avatar
dwspas
I used automotive laquer thinner on mine and it worked quite well. Don't know if the laquer thinner you get at Lowes is the same or not.
Old Nov 6, 2009 | 02:00 PM
That should work - just take it easy.
Old Nov 6, 2009 | 04:43 PM
bucwheat's Avatar
bucwheat
Lacquer thinner won't hurt vinyl or rubber
Old Nov 6, 2009 | 05:44 PM
killain's Avatar
killain
Oldtimer
I don't think your gonna be happy with Lacquer thinner. It isn't safe using it on Vinyl. I'd use paint thinner or Mineral Spirits and I'd use it on a Qtip instead. Can't take it back once you do it.
Old Nov 6, 2009 | 06:47 PM
aawil's Avatar
aawil
I think I'll try and find a spot that isn't too noticeable first and try them on, thanks for the input guys. Going to have to wait till tomorrow anyway.
Old Nov 6, 2009 | 09:59 PM
Tigershark3's Avatar
Tigershark3
I'd just clean around the letters then buy some inserts from one of the corvette vendors... Lacquer thinner could damage the vinyl as others have mentioned.
To Removing paint from dash?
