Dynaplug
Old Nov 7, 2009 | 05:26 PM
C5C6Norm's Avatar
C5C6Norm
From: Lower, Slower Delaware, formerly from Mobtown, MD (Baltimore)
Default Dynaplug
Pulled in my local gas 'n' go for fuel and a coffee this morning before going to work and what do I see shimmering from out of the tread of the front left tire? You guessed it, a phillips head screw imbedded nicely. Of course, I mutter the usual "oh ****', and a few other expletives.
Don't hear air leaking out, so I take my keys to move it side to side to see how far it went in, yup, the telltale "phissss" sound. I'm p!ssed now, don't have run flats on this one.
Then I remember, I put a plug kit in the glove compartment. In less than 30 seconds, pulled the screw out and jammed a plug in the hole.
Done, no leaking, no loss of tire pressure.
Great little tool, easy to use. Slide a brass type little bullet head connected to the plug in the end of the tool and shove it in, pull it back out. No twisting, no mess. Snip the eccess off, good to go.
The name of the plug kit is called "Dynaplug".
Old Nov 7, 2009 | 05:30 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
And where did you pick up the Dynaplug kit at? Sounds like a pretty good little tool to have around just in case.
Old Nov 7, 2009 | 05:35 PM
Indy's Avatar
Indy
I got something similar from Canadian tire, which is a automotive store here in Canada. ...around $6...
Old Nov 7, 2009 | 05:38 PM
C5C6Norm's Avatar
C5C6Norm
Geez, I'm sorry, I can't remember, geezer effect kicking in. I want to say Autozone or PepBoys.
Old Nov 7, 2009 | 05:42 PM
gorghamak's Avatar
gorghamak
St. Jude Donor '10-'11-'12-'13-'14
i googled dynaplug,that sent me to amazon.com
they have the,dynaplug 1007 tubless tire repair kit
for,14.99 hope this helps
Old Nov 7, 2009 | 05:49 PM
jgump's Avatar
jgump
Harbor Freight carries this.
Old Nov 7, 2009 | 05:50 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I carry a kit and a compressor also.
Old Nov 7, 2009 | 05:55 PM
Eddie 70's Avatar
Eddie 70
Z06 has got the compressor. Now I just need to pick up the plug kit.
Old Nov 7, 2009 | 06:04 PM
dquagliaroli's Avatar
dquagliaroli
Default Great Postt
Will be picking up one tomorrow. This is one of the reasons I love this forum.
Old Nov 7, 2009 | 07:17 PM
dobewillie's Avatar
dobewillie
cool product
Old Nov 7, 2009 | 07:54 PM
tlc0706's Avatar
tlc0706
So I staring at the picture.....light bulb clicks on......I need that! Hmmmm, cheapest mod done yet...
Old Nov 7, 2009 | 08:00 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Need a good pair of plyers as well!
Old Nov 7, 2009 | 08:37 PM
CatCam's Avatar
CatCam
Does the little metal tip stay in the tire??
Old Nov 7, 2009 | 08:44 PM
C5C6Norm's Avatar
C5C6Norm
Yes, that's what keeps the plug in place when pulling the tool out. When pushing the tool in, you have to go in until the handle stops at the tread, then quickly pull it out. Works well and is quick.
If you look at the mechanics of it, it's quite simple, the bullet style tip is like the point of a nail, the plug is attached to that point, making it go in easy. I would have used this years ago if it was available.
Old Nov 7, 2009 | 08:49 PM
CatCam's Avatar
CatCam
Okay - I got it! The metal tip stays "looped" on the plug on the inside.
At first I was thinking this little metal piece would be bouncing all over the inside of the tire and and could have damaged my pressure sensor.
Thanks for the clarification!
What a great forum!
Old Nov 7, 2009 | 09:02 PM
Looks like a nice plug kit. May have to check our local Harbor Freight and see if they have it.
Old Nov 8, 2009 | 12:10 AM
itzza427's Avatar
itzza427
Me TOO!! Got a couple of other things to look at there as well. Might just be time for a trip to South County!!
To Dynaplug
