[Z06] Octane
Old Nov 7, 2009 | 05:28 PM
Tom Beames's Avatar
Tom Beames
Default Octane
Got my ears pinned back by CF readers a month or so ago for running 87 octane in my 04Z. So, I 'googled' "Octane" and found some confirming reading about octance. Octane is only a resistance to knocking. My Z does not knock or deisel. She runs great. Read the octane articles. Great information.
Now then, several readers run 93 octane. They reminded me that the GM manual calls for 91. So, here is my question: IF I am wrong at 87, aren't they as wrong at 93??
BTW, I have switched back to 91 or 93 if available.
Old Nov 7, 2009 | 05:36 PM
ZYa's Avatar
ZYa
You won't gain benefits of a higher octane without the car being tuned for it. However, it won't cause knock. We don't even get 93 out here.
Old Nov 7, 2009 | 06:19 PM
Romulus's Avatar
Romulus
http://forums.corvetteforum.com/1551381628-post18.html
Old Nov 7, 2009 | 07:48 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
Higher octane only produces more power if you need it; you can actually make more power using a lower octane fuel because it burns quicker producing a faster bigger explosion in the cylinder.
The lower the octane number the quicker the fuel burns, when fuel burns quickly, it generally burns hotter or in this case makes a bigger bang which is what produces more power. The higher the octane number, the slower the fuel burns and with a smaller explosion and less heat. The only reason you need high octane fuel is when you need a slower burn rate such as high compression, you run a lot of ignition advance or you are forced induction.
Pretty much what Romulus posted in the link but dumb'ed down.
I ran race fuel in a junk lawnmower once, used it for cutting weeds in the alley where i wasn't taking the good lawnmower. It blew up, not sure why because it should have just be a waste of good gas but it crack the block and caught fire, didn't throw a rod either.
Old Nov 7, 2009 | 08:26 PM
dbaker's Avatar
dbaker
Here in the south we have 3 octane choices:87,89 & 93.
91 is the min recommended( less=not good/more=ok) octane for our Z's.
\db2
Carolina
Old Nov 7, 2009 | 08:31 PM
ZeeOSix's Avatar
ZeeOSix
Well, it could be your engine is retarding the timing due to slight knocking that you can't detect. If the engine is NOT retarding timing via the knock sensors, then higher octane is not needed to get the full HP potential out of the engine.
Many cars say premium fuel is "recommended for maximum performance" ... meaning with the higher octane the engine will not retard timing if nothing shows up on the knock sensors and give you full performance potential.
Old Nov 8, 2009 | 09:49 AM
Atok's Avatar
Atok
That's because the PCM is pulling ignition timing to keep it from knocking/pinging which could destroy pistons, rod bearings, etc. If you connected a scan tool and watched your knock retard you'll see for yourself. The knock sensors are way more sensitive than your ears.
For maximum performance you want the lowest octane that does not cause pre-ignition with optimum spark timing. GM has designed our engines to use 91 - 93 octane fuel. Sure you can use other fuel but higher or lower and you'll lose power.
Old Nov 8, 2009 | 12:02 PM
Z06supercharged's Avatar
Z06supercharged
Unless you are logging with a tuning program you dont even know if your car is pulling timing because of knock you cant hear. Go ahead and run the lower octane if it floats your boat and you think it works for your car.
Sure you dont hear it knocking cause its pulling timing or running off the low octane table for so long it wont ever knock or notice it.
I wouldnt run anything less than 91 in a Z06...
Try 7-11 87 octane gas cause its the cheapest and im sure your car will love it!
Old Nov 8, 2009 | 04:55 PM
JimbeauZ06's Avatar
JimbeauZ06
On the East Coast: Regular -87, Mid -89, Super - 93
Never even seen 91, but if they sold it I'd buy it instead of 93
Old Nov 8, 2009 | 05:43 PM
Tom Beames's Avatar
Tom Beames
It never ceases to amaze me. The post #8 is far and away the rudest and also one of the new dudes. Everyone else is not only more senior but so much more accommodating and provide meaningful information. I'm not a fanatic on 'Vettes but I love them and look to the CF for information. For example, I need "tars" and read about the pros and cons of each manufacturer on this site. To those who help I can only say "Thank you".
Old Nov 10, 2009 | 12:29 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
. My Z does not knock or deisel. She runs great. .
That's because the computer keeps the engine idiot proof.
Old Nov 10, 2009 | 10:49 AM
waktasz's Avatar
waktasz
Sometimes people need a smack in the head before they will listen to the truth.
/new guy
To Octane
