My driver's side door has developed a squeak now. Want to know if WD40 is a safe solution and if so, where exactly to spray on the hinges or if I need to use something else. Thanks
You shouldn't "hurt" anything (see how many times it's used to clean tar, etc.) but it probably won't last long.
Buy a spray can of grease (I forget the name - NAPA can tell you!) and use the WD40 to clean the area after you've treated the doors!
Gotcha. I just remember using it on my room door when it creaked and it went away immediately and effortlessly. Not sure where I can get this, any particular kind better or worse?
I just wasn't sure if there were any plastic parts or anything to shy away from in the hinge structure. Didn't want to break something while trying to fix something LMAO.
Use LPS-2 if you can find it, or other lubricants that coats, otherwise, you be spray WD-40 on it on a month to month basis.
As an avid gun owner, it's been long known to those who take great care of their firearms that WD-40 has no usefulness as a lubricant. It tends to gum up with continued use, provides minimal lubrication but does have it's place if caught in the rain to quickly shed the water from fine metal finishes. Most know that if your distributor gets flooded after running through a large puddle and kills the motor, a shot of WD-40 will get you going again because it's a water displacer, NOT a lubricant.
I personally like Breakfree CLP or Tri-Flow with teflon for lubrication on metal parts. For extreme use in dusty/dirty environments, my favorite it Militec-1 synthetic but it works best when heated to above normal temperatures to bond to the metal surface. Big advantage is it's a "dry" lubricant.
WD-40 will eliminate a squeak for a short while but so will water... or fish oil. There are uses for WD-40, my favorite... removing store stickers. It'll remove gum from hair too.
u cant tell me the squeek wont stop immediately as soon as u squirt WD-40 on it.. and the question "is it safe?".. yes
main ingrediant is fish oil
Myth: WD-40 contains fish oil.
Fact:
Consumers have told us over the years that they have caught some of the biggest fish ever after protecting their fish hooks and lures with WD-40. We believe this legend came from folks assuming that the product must contain fish oil since it appears to attract fish. Sorry Charlie®, it just ain’t so.
Use white lithium grease, i sprayed it on my driver's side door hinges almost 2 years ago, and zero squeaks!
Water resistant too. =)
WD-40 will only cure the problem temporarily, it's not really a lubricant, but it's designed to repel water and prevent corrosion.
I would recommend using WD-40 to clean the hinges real good, wipe off, then apply some white lithium grease (comes in a spray too, available at your local auto parts store). Wipe off any excess grease. (Open and close the door repeatedly so the grease spreads around the hinges).
I did this almost 2 years ago, and i'm telling you, the squeaks never came back!
