"Halo" LED C5 Tail Lights....
Old Nov 10, 2009 | 08:51 AM
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Default "Halo" LED C5 Tail Lights....
We have them in stock and ready to ship....
All orders come with a Free set of C5 Tail light seals
More info at the link below..
Corvette Halo LED Taillights
Old Nov 10, 2009 | 08:56 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Very nice, however I thought tail light seals were only needed when you performed the flush mount mod?
Old Nov 14, 2009 | 02:20 PM
southerncarparts
Supporting Vendor
No, actually the seals have nothing to so with the flush mount mod...
More info here
C5 Corvette Tail Light Seals
Thanks,
Jim
Old Nov 14, 2009 | 08:34 PM
83Camaro's Avatar
83Camaro
They look good, however in this pic, and others on your website, the illumination doesnt seem to be consistent between taillights.
Old Nov 15, 2009 | 08:46 AM
southerncarparts
Supporting Vendor
It is.....it is just the way the camera captures the light....they are exactly identical from light to light...
See ya,
Jim
Old Dec 1, 2009 | 11:44 AM
Zr-1Mike00's Avatar
Zr-1Mike00
Would it defeat the purpose of getting these LED tail lights by putting black out covers over them? Or will they shine just as bright
Old Dec 1, 2009 | 12:20 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
They will still shine bright. These things are VERY bright to begin with.
Old Dec 3, 2009 | 06:42 PM
southerncarparts
Supporting Vendor
You are correct!!!!
Jim
Old Dec 21, 2009 | 04:37 PM
Bills03Coupe's Avatar
Bills03Coupe
Per your description, the light draw less energy from the electrical system. Will the car's computer interpret that as a problem, and throw a code?
Old Dec 21, 2009 | 05:19 PM
southerncarparts
Supporting Vendor
Nope.....not at all.....
Old Jan 17, 2010 | 11:09 AM
Rundayo's Avatar
Rundayo
And no hyperflash harness is needed ? Just plug and running?
Old Jan 21, 2010 | 10:19 AM
southerncarparts
Supporting Vendor
You got it....
Old Mar 13, 2010 | 07:46 PM
ssidekickbp's Avatar
ssidekickbp
do the seals work if you have louvers on your lights?
Old Mar 22, 2010 | 06:40 PM
JtothaP's Avatar
JtothaP
These lights are very nice. They look amazing. I have these on my C5 and am about to do the Halo ring mod. I can't wait until they are done!
Old Jan 23, 2014 | 03:21 PM
southerncarparts
Supporting Vendor
Old Jan 30, 2014 | 04:45 PM
southerncarparts
Supporting Vendor
Old Jan 31, 2014 | 05:51 PM
C5Txfan's Avatar
C5Txfan
Curious ... another vendor that sells these same LED halos states that you have to change out your turn signal flasher AND your hazard flaster. Is that true ?
To "Halo" LED C5 Tail Lights....
Old Jan 31, 2014 | 06:20 PM
southerncarparts
Supporting Vendor
That's a knock off version...you don't have to with ours..
Old Jan 31, 2014 | 10:54 PM
Ralm1953's Avatar
Ralm1953
Default They do Hyper Flash
They are the best tail lights out there and get more comments than anything. These will hyper flash but that is easily solved by plugging in a hyper flash harness under the dash.
I also did clear front corners with LED Yellow / White bulbs and no hyper flash after the harness
Old Feb 3, 2014 | 02:50 PM
C5Txfan's Avatar
C5Txfan
Okay which is true. Ralm1953 says they do hyper flash and a harness is needed to eliminate it ?
