What should I do about this?
Old Nov 12, 2009 | 03:33 PM
PaintballaXX's Avatar
PaintballaXX
Default What should I do about this?
What you are about to look at is the bottom of the front passenger side quarter panel (the 1 with the side "vents"). As you can see its cracked where a screw is supposed to hold it secure. Right now the panel looks fine but I dont like the idea of it having this crack. Its easy to move with your hand without the screw holding in.
What do you guys suggest I do?
*Sorry for the blurry picture, camera cannot zoom in to something so close.
Old Nov 12, 2009 | 04:53 PM
Tech's Avatar
Tech
Bigger washer might hold it enough that it doesn't move.
Old Nov 12, 2009 | 05:12 PM
Indy's Avatar
Indy
How about drilling a new hole beside it and securing it with a metal screw...it makes it's own thread, so just drill the hole and screw tight. Indy
Old Nov 12, 2009 | 08:23 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Old Nov 12, 2009 | 08:29 PM
killain's Avatar
killain
Oldtimer
I'd take out the screw, Sand all parts of the fender where it's broken. Wear latex gloves, Use some strong Epoxy the prices back together after drilling some extra small holes IE:1/16 holes in the good part of the panel and once dried and sanded, paint and put a new screw with a slightly larger washer, and screw back together. I had something like that on my C-4 front fender and it's been holding tight for the last five years. So . .
Old Nov 12, 2009 | 09:37 PM
PaintballaXX
Thanks for the suggestions guys. Killain, what is the purpose of drilling ~1/16 holes? I like your idea but I don't follow on the drilling part.
Old Nov 12, 2009 | 10:39 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Looks like something came up off the road and WHACKED it!
You might try a larger washer or try to custom fab a rectangular washer to cover more area and paint it RED!
Thanks,Matt
Old Nov 12, 2009 | 10:58 PM
Retro99's Avatar
Retro99
i have the same issue with my passenger fender. u can see it sticking out on the bottom. im gonna look into it one of these days.
Old Nov 13, 2009 | 12:15 AM
Oldvetter's Avatar
Oldvetter
Try this
https://www.ecklers.com/product.asp?...8&dept_id=1493
Old Nov 13, 2009 | 12:22 AM
glorysends's Avatar
glorysends
I had this same issue on my passenger side as well. I drilled a new hole and put a bolt through there. Have had no problem!
Old Nov 13, 2009 | 01:47 AM
HawnHog's Avatar
HawnHog
Egads I didn't know this was so common. Same thing happened on my passenger side. I took a 1/2" X 2" metal strap and screwed one end to the panel, pulled it tight and screwed the other end to the frame. Looks good as new.
Old Nov 14, 2009 | 09:14 AM
cruisemon's Avatar
cruisemon
this damage is consistent with failure to use proper jack pads to lift the car. Count on majority of service facilities, especially smaller ones, to be unfamiliar with how to lift a C-5. Don't use jack pads, guarantee the quarters and side panels will be cracked.
Charlie
Old Nov 14, 2009 | 09:32 AM
DevilMan02's Avatar
DevilMan02
epoxy?
Old Nov 14, 2009 | 09:41 AM
vette.mix's Avatar
vette.mix
Old Nov 14, 2009 | 09:51 AM
YO-EL's Avatar
YO-EL
Originally Posted by DevilMan02
epoxy?
I believe thats how mine was fixed..
Common issue after many years..
Not certain how it occurred..
Car was always jacked up properly with pucks etc.
Old Nov 14, 2009 | 11:05 AM
Retro99's Avatar
Retro99
Charlie
Yup.. both my rockers are cracked in front of the rear wheels
I guess the previous owner doesnt use CF.com
Old Nov 14, 2009 | 03:56 PM
PaintballaXX
Thanks for all the help guys. I took my car in to a well known corvette body shop in my area (the guy has been restoring classic corvettes for years, as well as doing accident repairs for any gen corvette) and he told me to either have him fix the panel professionally or that I'd be just as well off buying an over-sized washer as suggested earlier. I will just do the washer trick in the intern. So again I say, thanks for all the help.
Old Nov 14, 2009 | 04:49 PM
fishdude7's Avatar
fishdude7
Same thing happened to my vette. My uncle tried to take it through the carwash and it cracked in the same spot. I was so pissed off. Im gunna drill an new hole for it soon and make it flush again.
Old Nov 14, 2009 | 04:53 PM
johnson-rod's Avatar
johnson-rod
Same here.
Wait until a nice hot day to pull the fender in tight.
Previous owner frequented automated car washes.
To What should I do about this?
