c6z06 Brake upgrade???
Old Nov 17, 2009 | 11:28 AM
Fratbragen's Avatar
Fratbragen
Default c6z06 Brake upgrade???
All, I know a larger wheel is required for this set up on a C5. I've read as much as possible and the set up seems to get mixed reviews as far as performance is concerned. Yes, it looks great, but it must perform to be worth it. Curious how many have done this and what your opinion is over the stock c5 set up. I can't imagine how it couldn't make a huge difference....
All the reveiws brag about how great the C6Z's brakes are.....
Thanks for your comment.
Old Nov 17, 2009 | 12:16 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
You need to do this, so glad I did it to my 99. You will need an 18" rim with the proper spacing like my Ace Slicks in Hyper Black
Old Nov 17, 2009 | 12:29 PM
BillY2KFRC's Avatar
BillY2KFRC
I did the C6 Z06 brakes with stainless lines on my car and am very happy. I haven't done any track days yet, but the car performs far better during aggressive street driving. Zero fade when attacking the back roads and give much more confidence above 100mph.
Here's a couple of pics: (I have since painted my centers black to cover the rust)
Old Nov 17, 2009 | 12:37 PM
chris holmes's Avatar
chris holmes
I did quite a bit of research, and from what I read, it seems that the C6Z brake package is good for looks, but not that great on performance. I ended up going with a Stoptech ST60/ST40 kit on my car. However, the C6Z brakes are about a third the price, and are more than adequate for street driving. Depends what you want
Old Nov 17, 2009 | 02:00 PM
Fratbragen's Avatar
Fratbragen
that's the tough part about this question. I personally have never had an issue with the stock units, but then again, I've never tracked the car. You can get a full c6Z set up for about $1800. The guys that do experience fade with these brakes must beat the living crap out of them. I've never read one review (automotic mag) regarding Z06 brakes that didn't praise them.
I'm probably going to upgrade to OEM Z06 wheels / tires sizes (yes I know they stick out a little, but saw a pic of the set up and they still look awesome), then bump up the Brakes.
Thanks for the comments.
Old Nov 17, 2009 | 02:57 PM
vette.mix's Avatar
vette.mix
this is an upgrade I would like to do down the road
Lancejoker's Avatar
Lancejoker
I was actually just thinking about this yesterday. Can someone post up some pics of a C6Z kit on a C5 with a 19" wheel up front? I would be thinking about it behind a 505A if I did it.
Old Nov 17, 2009 | 03:16 PM
chris holmes
Lance, it won't fit behind the 505a's. Already tried unfortunately.
Old Nov 17, 2009 | 03:45 PM
Lancejoker's Avatar
Lancejoker
Good to know. Just saved $1800 bucks. LOL
Old Nov 17, 2009 | 04:17 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
They will fit only if you have CCW do a custom wheel for you, Chriswtx did this with his 04 and the combo is sweet, just will not work on yours
Old Dec 15, 2009 | 08:14 PM
RockJustBelow's Avatar
RockJustBelow
Is that the same case for 19" 550's?
Old Dec 15, 2009 | 09:21 PM
therealdave's Avatar
therealdave
Just for comparison......here are the C6Z06 big brakes on a 2001 Z with iForged Aero's. 19's and 20's
http://i840.photobucket.com/albums/z...s/IMG_0231.jpg
Old Dec 15, 2009 | 10:03 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Default Its not an upgrade!
C5 brakes already happily engage the anti lock system, and don't fade in any normal street driving. That is all ANY brake system could do. Its not an upgrade.............maybe a side-grade.
Old Dec 15, 2009 | 10:06 PM
c5mtl's Avatar
c5mtl
does anybody know how big of a spacer would be needed to run these big brakes on ccw 505 19's front and rear
Old Dec 15, 2009 | 10:37 PM
therealdave
Agreed....But they sure do fill in the gaps when you go to bigger wheels!
Old Dec 15, 2009 | 11:17 PM
yaknow's Avatar
yaknow
I bougth new 18/19 wheels and then started looking at bigger brakes. Ultmately went with C6Z51 brakes due to front fitment issues. I'm satisfied with the performance and appearance but, a ton more brake dust to clean off the wheels. Just another option to consider if your already invested in wheels.
Old Dec 16, 2009 | 10:24 AM
RockJustBelow
It turns out they won't ...from CCW
"we can build a special configuration that will clear the c6z06brakes,
it would be a 9.5" front with 1" lip and 11" rear with 2" lip (as opposed to 10" wide front and 11.5" wide rears with 2" and 3" deep lip)"
To c6z06 Brake upgrade???
Old Dec 16, 2009 | 07:19 PM
Cali17's Avatar
Cali17
From: West Hollywood California ! Now Miami, Florida
Default ttt
There were two reasons I decided to go ahead with this "upgrade." First I wanted to change my wheels in the first place, and have 18's all around for optimal handling.
Second for a 6 piston front, 4 piston rear brake set up the cost was in the range of $5,000.00-$7,000.00. I did not have the money to put down that much for brakes. So I had to answer the peformance question to myself. I figured for my application the C6Z06 brakes will work for me.. I am not running the 24 hours of Le Mans or tracking my car every weekend. So for less than half the price of the other big brake kits around, I went with the C6Z06 brakes. Are they as good as Brembo or stop tech, AP racing, no they are not... but if you have the money to spend on those kits go for it, most people dont......
I will say this much, they have saved me more than a number of times, and i drive pretty hard, not to mention where I live there are lots of crazies out there driving, so I am glad I have them. Plus these brakes are strong enough to suck the front of my car down if I slam on them. So hope this helped someone find thier answer.
peace
Old Dec 16, 2009 | 07:53 PM
Dave concrete's Avatar
Dave concrete
The only real negative issues seem to be the high cost of pads when used in events.But in reality if you use the brakes the way it was intended for street and occasional track event it is a nice upgrade in looks and function.If your going to be doing track days a dozen or more times a season then a set of Stoptechs or similiar is needed.On the other hand C5 brakes with a killer set of pads stainless steel lines is a good set up as well.
Old Dec 16, 2009 | 09:14 PM
DonsLS1's Avatar
DonsLS1
CCW makes the 505A to fit that upgrade, you just have a 1'' front lip and 2'' rear instead of the 2 and 3 inch lip.
