Map LED lights only bright when door open
Old Nov 19, 2009 | 04:00 PM
waleedalot's Avatar
waleedalot
Default Map LED lights only bright when door open
I just replaced my map lights with LED lights.. They're only bright when the door is open or when i switch them on with my dimmer.. But when i manually turn them on with the switch, on the rear view mirror, they're not as bright. What can i do to change that?
Old Nov 19, 2009 | 05:32 PM
waleedalot's Avatar
waleedalot
Never mind i figured it out it was just a fuse
