Codes: Did I do a stupid thing?
Old Nov 25, 2009 | 12:42 PM
Aerovette's Avatar
Aerovette
Default Codes: Did I do a stupid thing?
I had my check engine light come one and read here how to scroll through the codes. I also saw that they all had an "H" after them (most anyway) which I understand is not a current code, but historical. My INTENTION was to clear the codes so the light would go off and then when it comes on again, only the code(s) that prompted the light would be the ones displayed. Is this incorrect? Have I lost valuable info by doing what I did? I should have asked first, but the light put me in a bit of a panic and I wanted it OFF.
Old Nov 25, 2009 | 12:51 PM
PostShawn's Avatar
PostShawn
My H codes come back after I clear all codes. Give it a couple days or a few start ups and check your codes again. The H ones will probably be there. I don't know if they ever go away if the problem has been fixed but if you just clear them the H codes will come back but shouldn't put on any warning lights. If a current code was there throwing a code causing a light to be on then if all you did is clear the codes and there really is a problem it will come back too after time. Mine's going through the same thing. I have about five H codes and one C code. I have to check what the C code is and address the problem next time it comes up.
Old Nov 25, 2009 | 01:11 PM
Jet-Jock's Avatar
Jet-Jock
You are ok. No problem if the problem still exists it will generate a new DTC from which you can chase then.
FYI, they will clear off anyway after so many ignition cycles and the problem doesn't reoccur.
Old Nov 25, 2009 | 01:44 PM
Aerovette's Avatar
Aerovette
LDCM had 6 codes. Not sure what that is all about and foolishly, I did not write them down. That should not prompt a CHECK ENGINE though should it?
Old Nov 25, 2009 | 03:33 PM
Bill Vett's Avatar
Bill Vett
Originally Posted by 8VETTE7
Post the codes here in this thread including the H or C that appears with the code and we can tell you. Guessing if a LDCM problem can trigger a Check Engine light is just that a guess.........
Yes the LDCM will set the CEL, Read Bill Curlee's sticky, I had the same problem and your problem could be in the bundle of wires in the door pillar or door. it's a long read but a quick fix. Bill
http://forums.corvetteforum.com/c5-t...tion-long.html
PAGE #16
Old Nov 25, 2009 | 04:10 PM
Jet-Jock's Avatar
Jet-Jock
Well let's see here's the list of DTCs:
CODE LIST
10-PCM - Powertrain Control Module
P0101 Mass Air Flow (MAF) System Performance
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0107 Manifold Pressure (MAP) Sensor Circuit Low Voltage
P0108 Manifold Pressure (MAP) Sensor Circuit High Voltage
P0112 Intake Air Temp (IAT) Sensor Circuit Low Voltage
P0113 Intake Air Temp (IAT) Sensor Circuit High Voltage
P0117 Engine Coolant Temp (ECT) Sensor Low Voltage
P0118 Engine Coolant Temp (ECT) Sensor High Voltage
P0118 Engine Coolant Temperature (ECT) Excessive Time to Closed Loop Fuel Control
P0131 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1
P0132 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 1
P0133 Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1
P0134 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1
P0135 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 1
P0137 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2
P0138 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 2
P0140 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2
P0141 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 2
P0151 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
P0152 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1
P0153 Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1
P0154 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1
P0155 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
P0157 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2
P0158 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 2
P0160 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2
P0161 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
P0171 Fuel Trim System Lean Bank 1
P0172 Fuel Trim System Rich Bank 1
P0174 Fuel Trim System Lean Bank 2
P0175 Fuel Trim System Rich Bank 2
P0230 Fuel Pump Control Circuit
P0300 Engine Misfire Detected
P0325 Knock Sensor (KS) System
P0327 Knock Sensor (KS) Circuit Front
P0332 Knock Sensor (KS) Circuit Rear
P0335 CKP Sensor Circuit
P0336 CKP Sensor Circuit Performance
P0341 CMP Circuit Performance
P0342 CMP Sensor Circuit Low Voltage
P0343 CMP Sensor Circuit High Voltage
P0351 Ignition Control #1 Circuit
P0352 Ignition Control #2 Circuit
P0353 Ignition Control #3 Circuit
P0354 Ignition Control #4 Circuit
P0355 Ignition Control #5 Circuit
P0356 Ignition Control #6 Circuit
P0357 Ignition Control #7 Circuit
P0358 Ignition Control #8 Circuit
P0410 AIR System
P0412 AIR Solenoid Relay Control Circuit
P0418 AIR Pump Relay Control Circuit
P0420 TWC System Low Efficiency Bank 1
P0430 TWC System Low Efficiency Bank 2
P0441 EVAP System No Flow During Purge
P0461 Fuel Level Sensor 1 Circuit Performance
P0462 Fuel Level Sensor 1 Circuit Low Voltage
P0463 Fuel Level Sensor 1 Circuit High Voltage
P0480 FC Relay 1 Control Circuit
P0481 FC Relay 2 and 3 Control Circuit
P0500 VSS Circuit (M/T)
P0506 Idle Speed Low
P0507 Idle Speed High
P0522 Engine Oil Pressure Sensor Circuit Low Voltage
P0523 Engine Oil Pressure Sensor Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit
P0562 System Voltage Low
P0563 System Voltage High
P0567 Cruise Resume Circuit
P0568 Cruise Set Circuit
P0571 Cruise Brake Switch Circuit (M/T)
P0601 PCM Memory
P0602 PCM Not Programmed
P0604 PCM RAM Performance
P0606 PCM Internal Communication Interrupted
P0608 VSS Output Circuit
P0650 MIL Control Circuit
P0654 Engine Speed Output Circuit
P0704 Clutch Switch Circuit (M/T)
P0705 Transmission Range Switch Circuit (A/T)
P0706 Transmission Range Switch Performance (A/T)
P0801 Reverse Inhibit Solenoid Control Circuit (M/T)
P0803 1-4 Upshift Solenoid Control Circuit (M/T)
P0804 1-4 Upshift Lamp Control Circuit (M/T)
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1114 ECT Sensor Circuit Intermittent Low Voltage
P1115 ECT Sensor Circuit Intermittent High Voltage
P1120 TP Sensor 1 Circuit
P1125 APP System
P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1134 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1
P1153 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
P1154 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
P1220 TP Sensor 2 Circuit
P1221 TP Sensors 1, 2 Performance
P1258 Engine Coolant Over Temperature-Fuel Disabled
P1275 APP Sensor 1 Circuit
P1276 APP Sensor 1 Circuit Performance
P1280 APP Sensor 2 Circuit
P1281 APP Sensor 2 Circuit Performance
P1285 APP Sensor 3 Circuit
P1286 APP Sensor 3 Circuit Performance
P1380 EB (T) CM DTC Detected- Rough Road Data Unusable
P1381 Misfire Detected - No EB (T) CM/PCM Serial Data
P1415 AIR System Bank 1
P1416 AIR System Bank 2
P1431 Fuel Level Sensor 2 Circuit Performance
P1432 Fuel Level Sensor 2 Low Voltage
P1433 Fuel Level Sensor 2 High Voltage
P1441 Evaporative Emissions (EVAP) System Flow During Non-Purge
P1514 TAC System MAF Performance
P1515 Command vs Actual Throttle Position Performance (PCM Module)
P1516 Command vs Actual Throttle Position Performance (TAC Module)
P1517 TAC Module Processor
P1518 PCM to TAC Module Serial Data Circuit
P1539 A/C Clutch Status Circuit High Voltage
P1545 A/C Clutch Relay Control Circuit
P1546 A/C Clutch Status Circuit Low Voltage
P1571 ASR Desired Torque
P1574 Stop Lamp Control Circuit
P1575 Extended Travel Brake Switch Circuit High Voltage
P1626 Theft Deterrent System Fuel Enable Circuit
P1630 Theft Deterrent System PCM In Learn Mode
P1631 Theft Deterrent System Password Incorrect
P1635 5 Volt Reference #1 Circuit
P1639 5 Volt Reference #2 Circuit
P1644 Delivered Torque Output Circuit
P1652 Powertrain Induced Chassis Pitch Output Circuit
28-TCS - Traction Control System
C1214 Sol Valve Relay Contact or Coil CKT Open
C1217 BPMV Pump Motor Relay Contact CKT Open
C1221 LF Wheel Speed Sensor Input Signal is 0
C1222 RF Wheel Speed Sensor Input Signal is 0
C1223 LR Wheel Speed Sensor Input Signal is 0
C1224 RR Wheel Speed Sensor Input Signal is 0
C1225 RF Excessive Wheel Speed Variation
C1226 LF Excessive Wheel Speed Variation
C1227 LR Excessive Wheel Speed Variation
C1228 RR Excessive Wheel Speed Variation
C1232 LF Wheel Speed Circuit Open or Shorted
C1233 RF Wheel Speed Circuit Open or Shorted
C1234 LR Wheel Speed Circuit Open or Shorted
C1235 RR Wheel Speed Circuit Open or Shorted
C1236 Low System Supply Voltage
C1237 High System Supply Voltage
C1241 Magna Steer Circuit Malfunction
C1242 BPMV Pump Motor Ground Circuit Open
C1243 BPMV Pump Motor Stalled
C1255 EBTCM Internal Malfunction
CEBCM Internal Malfunction
C1261 LF Inlet Valve Solenoid Malfunction
C1262 LF Outlet Valve Solenoid Malfunction
C1263 RF Inlet Valve Solenoid Malfunction
C1264 RF Outlet Valve Solenoid Malfunction
C1265 LR Inlet Valve Solenoid Malfunction
C1266 LR Outlet Valve Solenoid Malfunction
C1267 RR Inlet Valve Solenoid Malfunction
C1268 RR Outlet Valve Solenoid Malfunction
C1273 RF TCS Master Cyl Isolation Valve Malfunction
C1274 RF TCS Prime Valve Malfunction
C1276 Delivered Torque Signal CKT Malfunction
C1277 Requested Torque Signal CKT Malfunction
C1278 TCS Temporarily Inhibited By PCM
C1281 Steering Sensor Uncorrelated Malfunction
C1286 Steering Sensor Bias Malfunction
C1287 Steering Sensor Rate Malfunction
C1291 Open Brake Lamp Sw Contacts During Deccel
C1293 DTC C1291/C1292 Set Curnt/Prev Ign Cylce
C1294 Brake Lamp Switch Circuit Always Active
C1295 Brake Lamp Switch Circuit Open
U1016 Loss of Communications with PCM
U1255 Generic Loss Communications
U1300 Class 2 Circuit Shorted to Ground
U1301 Class 2 Circuit Shorted to Battery
38-RTD - Real Time Damping
C1650 ESC Module Malfunction
C1658 EEPROM Calibration Malfunction
C1710 LF Shock Absorber Solenoid (Short to Voltage)
C1711 LF Shock Absorber Solenoid (Short to GND)
C1712 LF Shock Absorber Solenoid (Open Circuit)
C1715 RF Shock Absorber Solenoid (Short to Voltage)
C1716 RF Shock Absorber Solenoid (Short to GND)
C1717 RF Shock Absorber Solenoid (Open Circuit)
C1720 LR Shock Absorber Solenoid (Short to Voltage)
C1721 LR Shock Absorber Solenoid (Short to GND)
C1722 LR Shock Absorber Solenoid (Open Circuit)
C1725 RR Shock Absorber Solenoid (Short to Voltage)
C1726 RR Shock Absorber Solenoid (Short to GND)
C1727 RR Shock Absorber Solenoid (Open Circuit)
C1743 Loss of Vehicle Speed Signal
C1760 LF Position Sensor (Out of Range)
C1761 RF Position Sensor (Out of Range)
C1762 LR Position Sensor (Out of Range)
C1763 RR Position Sensor (Out of Range)
C1768 Position Sensor Supply Malfunction (Overcurrent)
C1780 Loss of Steering Position Signal
C1786 RTD Control Relay Malfunction
C1787 RTD Control Relay Circuit (Open or Short to GND)
C1788 RTD Control Relay Circuit (Short to Voltage)
C1790 Ride Control Switch (Out of Range)
C1791 Ride Control Switch (Contact Malfunction)
40-BCM -Body Control Module
B0432 Rear Defogger Relay Circuit
B0433 Rear Defogger Relay Circuit
B0502 RH DRL Relay Circuit
B0503 RH DRL Relay Circuit
B0507 LH DRL Relay Circuit
B0508 LH DRL Relay Circuit
B0605 BCM Internal Memory Function
B0844 BCM Temporarily Inhibit ABS
B2403 Front Fog Lamp Switch Circuit
B2408 Rear Fog Lamp Switch Circuit
B2482 Backup Lamp Relay Circuit
B2483 Backup Lamp Relay Circuit
B2527 Horn Relay Circuit
B2528 Horn Relay Circuit
B2573 Hatch Release Switch Circuit (Short to Voltage)
B2578 RF Turn Signal Monitor Circuit (Short to Voltage)
B2583 LF Turn Signal Monitor Circuit (Short to Voltage)
B2587 Column Lock/Unlock Drive (A)
B2588 Column Lock/Unlock Drive (A)
B2592 Column Lock/Unlock Drive (B)
B2583 Column Lock/Unlock Drive (B)
B2597 Traction Control System Switch Circuit
B2721 PASS-Key Detection Circuit
B2722 PASS-Key Detection Circuit
B2723 PASS-Key Detection Circuit
B2735 PASS-Key Programming Mode Active
U1096 Loss of Communications with IPC
U1255 Serial Data Line Malfunction
60-IPC - Instrument Panel Cluster
B0516 Speedometer Signal Circuit Malfunction
B0521 Tachometer Signal Circuit Malfunction
B1512 DIC Switch 1 Signal Short to GND "FUEL"
B1517 DIC Switch 2 Signal Short to GND "GAGES"
B1522 DIC Switch 3 Signal Short to GND "TRIP"
B1527 DIC Switch 4 Signal Short to GND "OPTIONS"
B1532 DIC Switch 5 Signal Short to GND "E/M"
B1537 DIC Switch 6 Signal Short to GND "RESET"
B1542 Oil Temperature Circuit Short to GND
B1543 Oil Temperature Circuit Open
U1040 Loss of Communications with TCS
U1056 Loss of Communications with RTD
U1064 Loss of Communications with BCM
U1128 Loss of Communications with Radio
U1153 Loss of Communications with HVAC
U1160 Loss of Communications with LDCM
U1161 Loss of Communications with RDCM
U1166 Loss of Communications with SCM
U1176 Loss of Communications with RFA
80-Radio - Radio Not Found
99-HVAC - Heater, Ventilation, Air Conditioning
B0332 Outside Air Temp Sensor Short to GND
B0333 Outside Air Temp Sensor Open
B0337 Inside Air Temp Sensor Short to GND
B0338 Inside Air Temp Sensor Open
B0348 Sunload Temperature Sensor Open
B0361 Left Actuator Feedback Short to GND
B0363 Left Actuator Feedback Open
B0365 Right Actuator Feedback Short to GND
B0367 Right Actuator Feedback Open
B0441 Left Actuator Out of Range
B0446 Right Actuator Out of Range
B1016 Loss of Communications with PCM
A0-LDCM - Left Door Control Module
B2202 Left Window Up Switch Fault
B2204 Left Window Down Switch Fault
B2206 Right Window Up Switch Fault
B2208 Right Window Down Switch Fault
B2222 LT Mirror Select Switch Fault
B2224 RT Mirror Select Switch Fault
B2226 Mirror Right Switch Fault
B2228 Mirror Left Switch Fault
B2232 Mirror Up Switch Fault
B2234 Mirror Down Switch Fault
B2236 Left Door Lock Switch Fault
B2238 Left Door Unlock Switch Fault
B2242 Memory 1 Switch Fault
B2244 Memory 2 Switch Fault
B2252 Key Cylinder Switch Fault
B2262 Horizontal Position Sensor Fit
B2264 Vertical Position Sensor Fault
B2272 Left Mirror Motor Fault
B2274 Window Motor Fault
B2276 Door Lock Motor/Mirror Heater Fit
B2282 Battery #1 Fault
B2284 Battery #2 Fault
B2286 +5V Reference Fault
A1-RDCM - Right Door Control Module
B2203 Right Window Up Switch Fault
B2205 Right Window Down Switch Fault
B2237 Right Door Lock Switch Fault
B2239 Right Door Un-Lock Switch Fault
B2253 Key Cylinder Switch Fault
B2263 Horizontal Position Sensor Fit
B2265 Horizontal Position Sensor Fault
B2273 Right Mirror Motor Fault
B2275 Window Motor Fault
B2277 Door Lock Motor/Mirror Heater Fit
B2283 Battery #1 Fault
B2285 Battery #2 Fault
B2287 +5V Reference Fault
A6-SCM - Seat Control Module
B0846 Battery 2 Out of Range
B0851 Battery 1 Out of Range
B2002 Fore/Aft Seat Motor Open or Short to GND
B2007 Front Vertical Seat Motor Open or Shorted
B2012 Rear Vertical Seat Motor Open or Shorted
B2172 Seat Front Up Switch Shorted to GND
B2177 Seat Front Down Switch Shorted to GND
B2182 Seat Rear Up Switch Shorted to GND
B2187 Seat Rear Down Switch Shorted to GND
B2192 Seat Forward Switch Shorted to GND
B2197 Seat Reverse Switch Shorted to GND
B2605 Seat Front Vertical Position Sensor Failure
B2606 Seat Rear Vertical Position Sensor Failure
B2607 Seat Horizontal Position Sensor Failure
B0-RFA - Remote Function Actuation
B0605 Receiver Internal Memory Malfunction
B2805 No Transmitters Programmed
C2100 Left Front TPM Sensor Malfunction
C2105 Right Front TPM Sensor Malfunction
C2110 Right Rear TPM Sensor Malfunction
C2115 Left Rear TPM Sensor Malfunction
C2120 TPM System Malfunction (No Sensors Received)
C2121 TPM System Programming Malfunction (No Sensors Programmed)
U1000 Loss of Communication Undetermined
U1016 Loss of Communication with PCM
U1064 Loss of Communication with BCM
U1096 Loss of Communication with IPC
Old Nov 25, 2009 | 04:15 PM
Jet-Jock's Avatar
Jet-Jock
My guess is you had one or more of these:
Did you have a battery drain down or be replaced recently? A loss of voltage momentarily on the buss will cause all 6 of these codes. Loss of communication with either computer will generate a Check Engine.
Old Nov 25, 2009 | 07:24 PM
Aerovette's Avatar
Aerovette
So far...( I have a feeling more will show up later)
10-PCM - P0410 C = AIR system
99-HVAC-B0361 H = Left Actuator short to ground
??????? FIX ????????
The check engine light is OFF even with these codes.
Old Nov 25, 2009 | 08:39 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
My bet is an intermittent ground problem. Check G105 FIRST. Bill Curlee can hook you up with the ground locations. G105 is a common prob. Located under the engine block on the drivers side! Tightening that one up cured a ton of my woes.
Good luck!
Old Nov 25, 2009 | 09:30 PM
vette.mix's Avatar
vette.mix
Old Nov 28, 2009 | 12:01 AM
Aerovette's Avatar
Aerovette
I checked the AIR pump hose by the alternator and it did blow air for a short time and the other side actually had vacuum. It sounded like a pulsing kazoo however. As for the B0361, it has been joined by a 0363. Here is an odd twist. I get cold both sides, heat both sides, hot or cold on either side as I should, BUT, I have both codes and no matter what I set the airflow to (feet, vents, defroster) it evenly comes out of everywhere. I turn the fan up to MAX and the blower sounds like a hairdryer, but very little air is coming out. This is going to make me crazy. I have cleared the codes and they instantly return. I pulled the fuze and replaced it, no difference. Why am I getting a "short to GND" code when the actuator appears to be working AND why would the vacuum leak that it seems is the cause of the "air everywhere" send a code? I pulled the battery that was put in in July when I bought the car and noticed acid damage from a previous battery and two battery tray bolts missing. I pulled the tray out and everything under it looks very normal. Side note, who designed the stupid battery clamps? it broke when I re-attached it. Funky design and very weak. I so cannot afford to deal with this right now. Not with Christmas on top of me and my wife already wishing i did not have the car.
Old Nov 28, 2009 | 09:09 AM
Jet-Jock's Avatar
Jet-Jock
Have you gone through the link above on electrical issues and check the ground pak connectors? That would be the first area to check on the short to ground. Most likely the problem which is probably intermittent.
Sounds like you cranked down pretty good on the hold down bolt. Make sure the lips slips under at the rear of the battery (firewall side) then just snug the hold down bolt so that the battery is not moving. The tray bolts are torqued to 31Nm. The hold down bolt is only 18Nm and the terminal attachments are 15Nm. As you can see snug on the battery terminals and hold down bolt. 15-18Nm is not much force.
DTC B0361: The HVAC control module commands the left air temperature actuator to move by controlling the voltage supplied on the control circuit. A low voltage of 0 volts moves the door toward full hot. 2.5 volts stops the motor, 5 volts moves toward full cold. The instrument panel integration module determines the current position of the actuator by monitoring the voltage on the signal circuit. The feedback potentiometer is a function of the motor position. A high voltage of 4-5 volts indicates full cold door position. A low voltage of less than 1 volt indicates full hot door position. The HVAC control module controls the left air temperature actuator door positions in order to maintain the selected air temperature.
Conditions for setting the DTC. The HVAC control module detects the signal circuit is less than 5 counts (0.09V).
Action taken when the DTC sets: A default value will be used for the sensor data by the HVAC control module in an attempt to maintain the air temperature selected by the driver.
Conditions to clear DTC: Becomes history when the HVAC control module no longer detects the failure, history DTC clears after 100 fault free ignition cycles and cleared manually.
A disconnected or broken door may also set this DTC by allowing the left air temperature actuator to travel to its internal stops. (over travel)
At this point a scan tool is needed to measure voltage while the circuit is in operation.
I would not be surprised if you clean up all the grounds, it may also solve this problem. If after cleaning the grounds it still re-appears, then a full diagnostic is needed so at the very worst the door actuator needs to be replaced. But most steps of the diagnostic are looking for shorts to ground.
Hope this helps.
If you intend to keep the vehicle, I would invest in a set of Helm factory service manuals.
Oh, B0363 is basically the same DTC.
Old Nov 28, 2009 | 09:29 AM
Jet-Jock's Avatar
Jet-Jock
DTC P0410
A secondary air injection (AIR) pump is used on this vehicle in order to lower the tailpipe emissions during start-up. The powertrain control module (PCM) supplies a ground to the AIR pump relay, which energizes the AIR pump.
The PCM monitors the heated oxygen sensor (HO2S) voltages in order to diagnose the AIR system.
During the AIR test, the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages, and monitors the short-term fuel trim values for both banks of the engine. If the AIR system is operating correctly, the HO2S voltages should be low, and the short-term fuel trim should be high.
If the PCM determines that the HO2S voltages for both banks did not respond with the expected results during the tests, DTC P0410 sets. If only 1 sensor responded, the PCM sets either DTC P1415 or DTC P1416. The active DTC indicates which bank has the inoperative AIR system.
Conditions for setting the DTC: If the AIR pump turns ON during a closed loop operation and the HO2S voltage does not fall below 222mV for 1.3 seconds OR if the AIR pump turns ON during a closed loop operation and the short-term fuel trim does not change more than a predetermined amount.
Action taken when the DTC sets: The MIL lamp is turned on (Check Engine), a DTC is stored, the Freeze Frame/Failure Records are stored, the Failure Records are updated after the first failure of each ignition cycle.
It requires a scan tool and a special connector adapter.
Before doing any test be sure any debris is removed from the module connector surfaces and from the module connector gaskets. Gaskets prevent debris from contaminating the module.
Depending on what is found during the diagnostics, it could be a faulty connection, a faulty AIR pump relay or a faulty AIR pump. It could also be a blockage in the vacuum hose or damage to the hose.
Hope this helps.
Old Nov 28, 2009 | 09:31 AM
Jet-Jock's Avatar
Jet-Jock
Replace the fuse with a NEW fuse.
Very possibly the actuator for the door is defective.
Old Nov 29, 2009 | 12:39 AM
Aerovette's Avatar
Aerovette
clarification: I was referring to the terminal bolts that are tapered and clamp as the nut is forced in to the wider space in the "egg shaped" hole. I could still wiggle the cable so I gave it another turn and could still wiggle it. I gave it another turn and it split.
Old Nov 29, 2009 | 09:05 AM
rws.1's Avatar
rws.1
Anything that is a current issue will come back.
If it doesn't it was either previously addressed or was a hiccup.
Old Dec 17, 2009 | 01:42 PM
Aerovette's Avatar
Aerovette
After much procrastination, I pulled the battery. No damage to the vacuum lines. I pulled the cover behind the front passenger wheel and the lower fender and checked all vacuum lines. No problems found. I did not take the gas cap posts seriously, but when I could not find any other vacuum issue, I bought a new cap. The old one ratchets WAY too soon by comparison. I have not put the whole car back together yet, but I am crossing my fingers that the cap is the cause.
To Codes: Did I do a stupid thing?
Old Dec 19, 2009 | 12:24 PM
Aerovette's Avatar
Aerovette
The car is back together with a new gas cap. No codes yet (only running about 30 minutes) but the heater/AC still blows out of every vent regardless of the setting. I give up. I'll just have to find someone I trust to work on it. What is the Corvettes of Houston reputation for repairs? I have an extened warranty, if they take them. I hate when something does not work right and this is really bugging me.
Old Dec 19, 2009 | 01:19 PM
COHMATT's Avatar
0COHMATT
Former Vendor
Bring it by we will take a look at it. We do accept extended warranties.
Old Dec 19, 2009 | 01:29 PM
Aerovette's Avatar
Aerovette
Thanks Matt. I have not been out to your place in several years. My best bud bought a car from you a while back and was very pleased with the transaction, but I know nothing about your repair shop. Sorry, had to ask the question. I'll try to bring it by after the holidays.
