NEED HELP W/ HIDs
Old Nov 26, 2009 | 12:15 AM
markoo's Avatar
markoo
Default NEED HELP W/ HIDs
Installed new HID lights, high beam, low beam & fogs. Now when i turn on the running lights the head lights go up Any help would be great. Thanks,
Mark
Old Nov 26, 2009 | 12:43 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have never had that trouble, I have read about the lights not going down when turned off, Did you install the resistor to simulate a load?
That is a strange one, I don't see why the lights would go up if just the parking lights are on. Someone will chime in I am sure.
Bill
Old Nov 26, 2009 | 12:47 AM
markoo's Avatar
markoo
I installed a small marker light for load.
Old Nov 26, 2009 | 01:05 AM
Mr.Bill's Avatar
Mr.Bill
How about installing any relays for the High and Lows to be on at the same time?
Old Nov 26, 2009 | 01:10 AM
markoo's Avatar
markoo
Yep! I do have that installed but never had any problem tell installing the HIDs.
Old Nov 26, 2009 | 01:14 AM
Mr.Bill's Avatar
Mr.Bill
You didn't do any wire splicing at all?
I wish I had an answer for you.
Bill
Maybe your switch is acting up?
Old Nov 26, 2009 | 09:01 AM
JropTop's Avatar
JropTop
try cycling your switch on and off a cple of times,and see what it does,see if it works then,with HID installed and checking the operation of them with the key just in the on position can do wierd things
Old Nov 27, 2009 | 03:04 PM
nascar57's Avatar
nascar57
I had that problem after I initally installed my hid lows. What I found out is these hid's will do all kinds of strange stuff if the battery is the least bit low on charge. My problem went away after the battery was fully charged. Even now sometimes if I shut my lights off after the engine is shut off the buckets will stay up. Always turn off and on the lights with the engine running. I dont use the twilight sentinel.
Old Nov 27, 2009 | 07:28 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
It's actually pretty common with hids. Some do it and some don't. I still haven't figured out why. Some say the gears might be going out, but I changed mine both out and still have that happen. A minor drawback for better lighting.
Old Nov 27, 2009 | 09:30 PM
craig04c5's Avatar
craig04c5
So do the buckets go back down after turning the "running lights" off? Are running lights the same as what some people call parking lights? I have the HID low beams from JWMotoring and so far haven't had any issues but I want to know what to do just in case I do. BTW I love them.
Old Nov 27, 2009 | 10:28 PM
JW Motorsports
Banned Scam/Spammer
Yes they go back down once you turn them off. Normally they wouldn't go up. I've only known it to happen if you install the fogs. If just lows you shouldn't experience it.
Dudeurgettnavette's Avatar
Dudeurgettnavette
I've never had that problem on my C5
Old Nov 27, 2009 | 10:31 PM
JW Motorsports
Banned Scam/Spammer
After scanning the thread I believe
there are two things being brought up here.
What nascar57 is talkin about is caused by not
having the car turned on while turning the lights off. We do suggest keeping the engine running while turning your lights off in order for the resistor to work properly.
Old Nov 27, 2009 | 11:24 PM
mtndv8's Avatar
mtndv8
Default Mine would occasionally come up when I turned on the parking lights, too
I had that problem when I had the same mods.
OEM housings with HID bulbs (and ballasts).
HID's in all three locations and the lows/fogs "always on" relay mod.
This would happen intermitently and all while an inline resistor was installed.
I could never figure out why...
Now that I'm running projectors with HID bulbs and the same ballasts, same relay mod and in fact no change to the wiring, the lights go up and down as they should.
Weird?
Old Nov 28, 2009 | 09:34 AM
craig04c5's Avatar
craig04c5
Thanks for the info Jonathon. I am considering getting your fogs also in the not to distant future.
To NEED HELP W/ HIDs
