My 2003, Z06 has 5300 miles on the car. I don't think my brakes are bad but they sure squeel when I brake. Is there anything I can do to reduce the squeeling without taking it into the shop. Any kind of spray or solution I can put on the rotors or anything else I can do (I'm mechanically challenged). Thanks in advance.
Remove brake pads and put anti-squeal aluminum "pads" on back of your pads and/or lubricate BACK of pads with high temperature disc brake grease.
Then bed in pads by stopping form 30 mph to 5 mph about 10-20 times. Then either park car or drive for 15 minutes (without using brakes much) to let brakes cool.
I agree with the posts above. I recently added some new Baer drilled rotors and new factory pads. I bedded the rotors per the directions, but ended up with a sqeal on light braking.
I bought some synthetic caliper grease and ended up taking the pads back off and added the grease to the 'ears' of the pads where they slide on the factory shims.
