[Z06] OEM Wheel advice needed
Old Nov 26, 2009 | 10:55 AM
AnthonyTek's Avatar
AnthonyTek
Cruising
Default OEM Wheel advice needed
While getting a new tire mounted and balanced on my drivers side rear wheel, the tire shop showed me the wheel is bent. The tire mounted fine, and they were able to balance it, but it did have an observable wobble while it was spinning on the balance machine. I do notice a vibration which could be caused by the wheel. What are my options for getting the wheel itself fixed? Is it cheaper just to buy a used replacement?
'01 Z06
Old Nov 29, 2009 | 10:16 AM
TEXHAWK0's Avatar
TEXHAWK0
I don't know which is cheaper, but if I had a bent wheel I would just replace it.
Old Nov 29, 2009 | 10:49 AM
81c3's Avatar
81c3
You should be able to pick up a set of 2 from the for sale section on this forum.
To OEM Wheel advice needed
