Installed insulation kit
Old Nov 28, 2009 | 01:10 PM
tslick98's Avatar
tslick98
Default Installed insulation kit
Well i installed the kit today. My intensions were to take pictures along the way but once i got into it i kept forgetting. I also put down some 1/4" closed cell foam insulation first.
the tear down
install begins
here's a pic of the foam that's underneath
together again
The final verdict. It took me about seven hour to complete. I went for a ride after finishing the job. Riding around town on city streets there's a noticable drop in the noise level. Driving on the highway was a bit disapointing. The noise level wasn't that much differant from before.
In my opinion it really wasn't worth my money, time ,and effort.
Old Nov 28, 2009 | 01:34 PM
vette.mix's Avatar
vette.mix
I purchased the same kit you did. Then I got talking to a few people and they told me to get great results contact the people at second skin- for about 500 buck they have a couple of produces that will make your Vette quite as a luxury car. I haven’t purchased it yet but plan to for a spring install.
Old Nov 28, 2009 | 02:39 PM
Hammer99's Avatar
Hammer99
I appreciate the pics, write up, and most of all your opinion. Thanks!
Old Nov 28, 2009 | 02:43 PM
jrose7004's Avatar
jrose7004
That's a great mod!
Old Nov 28, 2009 | 03:44 PM
tslick98's Avatar
tslick98
Wish i'd a went this route.
Old Nov 28, 2009 | 03:48 PM
csexton's Avatar
csexton
Chuck
Old Nov 28, 2009 | 05:53 PM
MTPZ06's Avatar
MTPZ06
Thinking of doing this on my C5Z as well...my primary concern really isn't noise reduction as much as reducing heat soak coming in through the tunnel. Have you noticed a reduction in the temp of your console?
Old Nov 28, 2009 | 07:04 PM
vette.mix's Avatar
vette.mix
I was getting ready to install my kit and just lucked accross someone who went through this and gave me the heads up. The kit you installed will decress the heat and some noise level and you can always add to it. I'm thinking about adding all when I get around to it. The one problem with the "skin" kit is that it will add about 40 lbs to your Vette.
Old Nov 28, 2009 | 07:06 PM
vette.mix's Avatar
vette.mix
BTW great write up
Old Nov 28, 2009 | 07:09 PM
dobewillie's Avatar
dobewillie
good write up and job
Old Nov 28, 2009 | 07:35 PM
tslick98's Avatar
tslick98
I only drove it for about 30 minutes and there was no heat but probably
wasn't long enough to tell. Will let you know.
Old Nov 28, 2009 | 08:09 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
I installed the same kit last winter and was also a bit dissappointed with the sound level ( didn't drop as much as I expected ) however I can say the there is definately much less heat in the tunnel area. I also installed a coated tunnel plate so I'm sure that also attributes to the heat reduction... IMHO, not a bad mod for the cost as there is some improvement overall.....
Old Nov 28, 2009 | 08:30 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Did mine a while back too - and like you said on the road around town great but the highway is a different story!
But on the flip-side the heat between the colum center and seats is alot better I think it was worth it
Good job and nice Vette too
Thanks,Matt
Old Nov 28, 2009 | 08:48 PM
tlc0706's Avatar
tlc0706
Interesting.......Thanks for your opinion.........
Old Nov 29, 2009 | 12:54 AM
Mike McCoy's Avatar
Mike McCoy
All these insulation kits and rolls should be called heat reduction as opposed to sound reductuon. Sound reduction can only be reduced to any great amount by creating an airtight barrier between your ears and the noise being reduced. Think ear plugs. The tire/road, engine, transmission, drivetrain and airflow/wind can't really be lowered if you have any windows lowered or partially lowered. It can be muffled a bit, but not much. Any sound control system that might reduce some body noise would have to be a semi rigid rubber glued to the balsa floor pan and metal tunnel. Actually the balsa floor plan works pretty good as sound control by it's self. I would like to see an impartial laboratory study of these products to show any great amount of sound control achieved.
The insulation blankets, however, do reduce heat coming into the car as they are directly between the heat source and the interior. And do work well.
Old Nov 29, 2009 | 01:24 AM
mosimann's Avatar
mosimann
Used Frost King on mine and got a good difference. It was hard to drive and talk on the phone, now it's ok.
Old Nov 29, 2009 | 09:58 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nice write up and thank you for the honest opinion
To Installed insulation kit
Old Nov 30, 2009 | 01:25 AM
Scriz's Avatar
Scriz
I agree with the others on the noticeable heat reduction and minimal noise reduction from the foil kits offered by some of the vendors. Along with the foil, I also added some pretty heavy duty sound damping sheets (which I forget the name of at this time) to the hatch area, the large area behind the seats and the floor pan to lessen vibration. It works ok to lessen engine/exhaust noise (b&b route 66 with bassanni x pipe), but the road/tire noise is still very annoying. I am going to look into some Dynomat for specific locations in a few months and see how that works.
Chris
Old Nov 30, 2009 | 08:03 AM
vette.mix's Avatar
vette.mix
Chris
I would suggest giving secound skin a call, they seem to know what there talking about
Old Dec 1, 2009 | 02:21 PM
Scriz's Avatar
Scriz
Is second skin a foam layer with a rubber backing? If so, that is what I have in the large flat areas of the car already. I need something more maleable to stick in some of the smaller, odd shaped places in the car. The stuff I used was HEAVY. It worked well until the X pipe went on. That made my car louder instead of smoother. If I add headers I am going to go deaf so sound reduction is going to be a neccessity.
Chris
