09-2010 mods
Old Nov 28, 2009 | 07:22 PM
RockyF150's Avatar
RockyF150
Default 09-2010 mods
Ok so I figured I would go ahead and start another one for this year. I had some free time and figured I would take on the underside of the trunk. So flat black from the factory looks ok...but...thought this might be a little better.
Base/clear
Then figured lets make some inserts. This is just cardboard, double thick. Then covered with black felt.
How to get them to stay...well after some much thinking and testing the double sided tape. It does stick to the felt pretty well. so...thats the way I went. We'll see what happens in time.
Whats your thoughts?
Old Nov 28, 2009 | 07:51 PM
tslick98's Avatar
tslick98
Lookin good. I think it gives it a more finished look.
Old Nov 28, 2009 | 08:01 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Looks good.
i would advise replacing the inserts with carpet or vinyl wrapped MDF for a more perminant and sturdy solution. You could use the cardboard as a template saving yourself a LOT of sanding/cutting time.
As a mounting solution, you could use velcro on the top to make them removeable or double sided tape to make them semi perminant.
Old Nov 28, 2009 | 08:39 PM
Johnson 92's Avatar
Johnson 92
C5 of the Month 6/13
Old Nov 28, 2009 | 09:08 PM
tlc0706's Avatar
tlc0706
You are a very creative person and do so very nice work.....
Old Nov 28, 2009 | 09:56 PM
Very nice job on the inserts. Makes it look so much better.
Old Nov 28, 2009 | 11:01 PM
Hammer99's Avatar
Hammer99
I like!
Old Nov 29, 2009 | 07:54 AM
JohnnyDee's Avatar
JohnnyDee
2023 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (performance mods)
2017 C5 of the Year Finalist
Old Nov 29, 2009 | 08:10 AM
IBCAMN's Avatar
IBCAMN
Looks great! Now what? It's only November, what are you going to do for December, January, February and March? It's a long winter.
Old Nov 29, 2009 | 09:49 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Old Nov 29, 2009 | 09:51 AM
rdline's Avatar
rdline
once the clear was added it looks nice, I am so so on inserts , mirrored plexi is very cheap.
Old Nov 29, 2009 | 04:05 PM
RockyF150's Avatar
RockyF150
Thanks. I think so too.
Originally Posted by TheRadioFlyer
Looks good.
I see what you mean. This isn't the normal 1/8" thick cardboard. This is 1/4" thick. And it's light weight. And it is sturdy.
As far as mounting we'll see if this double sided tape works permanently or not. It certainly is doing the trick thus far.
Thanks for the compliment
Well you'll just have to keep an eye on whats next. Honestly I'm not sure. I'd like to get a carravaggio spoiler and a set of wheels and tires 18's all around. 12 wide in rear. and black. I'm on the lookout atleast for something along those lines on wheels.
Thanks to all for compliments and suggestions.
Old Nov 29, 2009 | 07:14 PM
dobewillie's Avatar
dobewillie
Congrats on a great looking job
Old Feb 13, 2010 | 03:55 PM
RockyF150's Avatar
RockyF150
Default Flush Mount tail lights
Today I figured it was time to do this...went to home depot and $9.44 later.
8- 1" Nylon Spacers
8- 2" panhead screws
1- 10ft long rubber foam weatherseal
Cut 1/4" off two of the 1" nylon spacers for the corner screws.
And before bolting them up I stuck the screws in a cardboard box and hit the heads with some black rattle can I had.
Also take a small straight screw driver, wrap the head in 3m tape. This helps poke the weatherseal in w/o scratching paint.
Before:
After:
And a helpful hint, take some 3m tape, tape the nylon spacers in place so you're not fighing with them.
Old Feb 13, 2010 | 04:01 PM
ronssito's Avatar
ronssito
Old Feb 13, 2010 | 04:07 PM
JerzeyJoe's Avatar
JerzeyJoe
What is all the white stuff showing around the perimeter of the light?
Old Feb 13, 2010 | 04:13 PM
RockyF150's Avatar
RockyF150
I noticed that when I took the shot. It's the foam weatherseal. It must be the flash b/c it's all black looking at it.
You can see in the final shot, the close up, I had the flash off to show the tape on the nylon and you can see the light next to it was already flushed and it's all black.
To 09-2010 mods
