Tire help!
Dec 8, 2009 | 09:34 PM
Tire help!
1999 stock FRC. will likely order rims with the following specs...
FRONT WHEEL SIZE: 17x9.5
FRONT WHEEL OFFSET: 54mm
REAR WHEEL SIZE: 18x10.5
REAR WHEEL OFFSET: 56mm
BOLT PATTERN: 5-120.65
adding these tires...
Front 245/45-17
Rears 275/40-18
opinions?
looking for tire tips and ideas. daily driver and money is an object.
Dec 8, 2009 | 09:40 PM
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Quote:
Originally Posted by
pokeyjones
Front 245/45-17
Rears 275/40-18
opinions?
Stock sized wheels and tires. Cheap tires - General Exclaim UHP, find them at Tire Rack.
Dec 8, 2009 | 09:59 PM
How wide can I go with the above rims?
250-255/40-17?
285-295/35-18?
thanks gang.
Dec 9, 2009 | 10:22 AM
Why not go for bigger wheels?
18x9.5 front 275/35-18
19x11 rear 305/30-19
Dec 9, 2009 | 01:12 PM
250-255/40-17?
285-295/35-18?
thanks gang.
you can go wider than that
Dec 9, 2009 | 02:34 PM
The wheels you want are the stock Z06 sizes - go with the stock Z06 size tires too (265-40/17 and 295-35/18)
