Exterior temp sensor
Old Dec 10, 2009 | 10:42 PM
dlivewyer's Avatar
dlivewyer
Default Exterior temp sensor
My exterior temperature always says 69. Is the sensor bad and if so, where is it?
Old Dec 10, 2009 | 11:09 PM
65GGvert's Avatar
65GGvert
It's cheap and easy to change. Unplug the old, plug in the new. Check for loose or corroded pins on the plug when you change it. Under the passenger side skid rail, on the frame, near the horn.
Old Dec 10, 2009 | 11:12 PM
dlivewyer's Avatar
dlivewyer
Thank you sir.
Old Dec 11, 2009 | 12:40 AM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
I can think of a lot worse numbers it could be stuck on
Old Dec 11, 2009 | 12:45 AM
Carcass's Avatar
Carcass
Might just be a loose connection,because if you unplug it,the display will default to "69"
Also does that if it's just "bad"
reminds me of an old girlfriend....
Old Dec 11, 2009 | 12:46 AM
dobewillie's Avatar
dobewillie
Funny how things work out
Old Dec 11, 2009 | 08:23 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
I accidentially left mine plugged in when I removed the radiator cover and pulled the wires out, I havent fixed it yet, and my temp stays on 69 also....
Old Dec 11, 2009 | 11:37 AM
At least it is one of the cheaper parts to replace on the car and easy to swap out.
Old Dec 11, 2009 | 11:45 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I was thinking the same thing.
Old Dec 11, 2009 | 11:48 AM
dlivewyer's Avatar
dlivewyer
You know that had to be a joke for whoever set that default #.
To Exterior temp sensor
