[Z06] cut out
Old Dec 18, 2009 | 02:38 PM
camaroracer91's Avatar
camaroracer91
Default cut out
if I went with these cut outs, would I need two of these, or is this kit all i need
http://www.texas-speed.com/shop/item...d=248&catid=57
Old Dec 19, 2009 | 12:24 AM
SVTBAIT's Avatar
SVTBAIT
2015 C5 of Year Finalist
You will need two.
BUT, do not simply order two. I believe that you'll need a controller to control both at the same time. I am fairly certain you can get it as a package deal.
Old Dec 20, 2009 | 09:40 PM
TEXHAWK0's Avatar
TEXHAWK0
If you like these, you might want to order directly from QTP.
http://www.quicktimeperformance.com/QTEC/index.php
Just installed some on a '07 Z06, and instead of a manual switch, I found a remote control relay to open and close the valves. They can be controlled with a manual DPDT switch provided by QTP, or a fancy controller if you want a readout of percent open. The remote relay needs to be a polarity reversing relay to change direction on the butterfly valve motors.
To cut out
