[Z06] New Vararam Install
Old Dec 19, 2009 | 01:04 PM
cole925's Avatar
cole925
Default New Vararam Install
I didn't want to jack the Vararam sale thread, so here we are.
I took out my Blackwing, it was pissing me off, so I am back to 100% stock, just ordered the Vararam yesterday, can't WAIT to install that bad boy over Christmas leave.
I did a Z06 forum search, couldn't find any threads with good Vararam problem discussions (maybe I should have searched in the parts section, I don't know, not too worried about it honestly).
Anybody got a link to such a discussion (common problems, remedies, etc.)? If not, can we start one here?
Common problems, where exactly parts are not fitting, specific places you have trimmed (with pics), y'all get my drift....
Old Dec 19, 2009 | 01:14 PM
TheDingo's Avatar
TheDingo
Not many issues with that application from my understanding. I cannot say from personal experience as I had a Callaway Honker for a while. Anyway, I think the biggest complaint is fitment issues with the shroud. I could be wrong.
It should be an easy in. Good luck w/ it all, and thank you for your service to this great country.
Merry Christmas
Old Dec 19, 2009 | 02:20 PM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
How was the Blackwing pissing you off?
Old Dec 19, 2009 | 02:29 PM
Dave_2003_TRZ06's Avatar
Dave_2003_TRZ06
I just installed the Vararam and to be honest, it was fairly easy. The only thing I would recommend is having a buddy helping when it comes time to fasten the air ducts to the fascia and when aligning/fastening the two air ducts together. I did this solo, but it would have been nice to have a second pair of hands.
Old Dec 19, 2009 | 03:52 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
just what i have been thinking about... i'll pay shipping if you want to get rid of it..... it would be my 1st mod...
Old Dec 19, 2009 | 04:03 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
I didn't have much trouble at all when installing on my Z. In fact, I think I had it easier than non-Z owners because I had no foglights or foglight wires or foglight housings to dink around with.
I used Cajundude's instructions since they are 15,000 times better than the little flyer you get with the kit:
http://www.cajundude.com/vararam.htm
I'd say most of my time was spent just removing all the paneling under the bumper; and then cleaning out all the crud I found under the radiator's front panel. It's amazing what I found up there: a plastic bag, a dead bird, at least 5 diff. types of leaves; millions of insects, some tape, a drink cup lid... a treasure trove to be sure.
Old Dec 19, 2009 | 06:26 PM
Edmond's Avatar
Edmond
I'm also interested in why the Blackwing pissed you off. I have that on my Z. I figured that it was probably the easiest to install!
Old Dec 19, 2009 | 07:46 PM
Stevo92z28's Avatar
Stevo92z28
I like my blackwing.
Old Dec 20, 2009 | 04:05 PM
DansBlkonBlkZ06's Avatar
DansBlkonBlkZ06
You need to follow Cajundude's instructions. They are priceless. The only problem I had was that my Z06 front screens had sheet metal screws that got in the way of the Vararam air ducts. I had to drill a hole into the duct to allow room for the screws. Don't get the power duct option. I'm having a lot of check engine lean codes since I put it on. I changed back to stock. With the stock flexible hose end I can remove the air filter much easier now.
Don't forget to clean out your radiator with an air hose. I found so much crude on the radiator I was surprised that I wasn't overheating. Also, while you are under the car you might want to put a protective screen under the radiator to keep trash out of the radiator.
Take your time. They say an easy install, but it took me a good 5 hours (allowing for beer breaks and cleaning out radiator).
Old Dec 20, 2009 | 05:08 PM
Dave_2003_TRZ06
Just an FYI... You could have just flipped those screen screws and mounting tabs, so the screw faced upwards...
Old Dec 20, 2009 | 07:25 PM
DARRYLZO6's Avatar
DARRYLZO6
Ditto on the question of why the Blackwing pissed you off? I have a Blackwing filter installed on the Vararam power duct with a modified radiator shroud and it works flawlessly.
Old Dec 22, 2009 | 02:39 PM
Steve20's Avatar
Steve20
first thing to do with the Vararam before you unwrap anything, is test the fit with the filter in the filter mounting area.
Steve
Old Dec 29, 2009 | 10:42 PM
cole925's Avatar
cole925
Install is complete... success!! Cajundude's instructions were 100% priceless, thanks for the hookup.
I've gotten a LOT of questions about the Blackwing (even a PM haha). I was not getting the performance gains that my friends with Vararams were experiencing and the design seemed..... ?inadequate? from the start. No major manufacturing defects or anything, just didn't live up to competitor advantage.
Thanks for the help guys.
Old Dec 29, 2009 | 10:54 PM
ZEE-OH-6's Avatar
ZEE-OH-6
I am contemplating the VARARAM - do you really feel the difference or is this all hype ?
How hard is it to change the filter and how often do you need to do it ?
Old Dec 30, 2009 | 12:19 AM
bumble-z's Avatar
bumble-z
Yes the Vararam will make a difference in performance. Need to take the filter out & keep it cleaned periodically. Not hard to install, or to pull filter out for cleaning. I suggest having screens in the fog light openings. Good luck.
Old Dec 30, 2009 | 08:54 AM
ZEE-OH-6's Avatar
ZEE-OH-6
Originally Posted by bumble-z
Yes the Vararam will make a difference in performane. Need to take the filter out & keep it cleaned periodically. Not hard to install, or to pull filter out for cleaning. I suggest having screens in the fog light openings. Good luck.
Thanks, I have a ZO6 so the screens are already in-place.
Old Dec 31, 2009 | 03:29 PM
cole925's Avatar
cole925
I drove 700 miles yesterday.... Vararam works like a charm.
I could definitely tell a difference from the Blackwing (better, of course).
To New Vararam Install
Old Dec 31, 2009 | 04:07 PM
ZEE-OH-6's Avatar
ZEE-OH-6
WOW, that's a lot of miles - I ordered mine today, cannot wait to install it
Old Jan 1, 2010 | 11:28 AM
Edmond's Avatar
Edmond
You guys got me thinking about ditching my Blackwing for a Vararam.
Ah, not until I get back from where Uncle Sam sends me next.
Old Feb 20, 2010 | 03:00 PM
hdff's Avatar
hdff
i installed my vararam 2 weeks ago, seems pretty sweet to me, especially since i went from stock. i didn't think it was possible but now when i drive my is even bigger.
