lost headlight motor cover help!
Old Dec 20, 2009 | 04:42 PM
1sickz51vette's Avatar
1sickz51vette
Default lost headlight motor cover help!
About 4 months ago I replaced the headlight gear with a plastic one (temporary fix) as I needed it asap and thought I tightened the motor cover good enough... Somehow it managed to come loose and fall off, now the shaft and and gear comes loose when i hit bumps and the headlight falls down. It's pretty dangerous because i have to pull over on the highway and stuff to fix it, and I can't find just the cover anywhere. Is there anything I can do, or where can I find a motor cover... I don't want to spend $300 on a used fiero headlight motor from ebay, or get depo's as i like the popups.
Old Dec 20, 2009 | 04:56 PM
2000lambovette's Avatar
2000lambovette
There is a place called cleveland pick a part and he probably has all the parts you would need to fix that and good prices becasue it is all used. Good luck
Old Dec 20, 2009 | 05:24 PM
1sickz51vette
I figured there would be somewhere that might have the part, these headlight motors are nothing but problems. I found a saturn headlight motor and the cover looks the same for, which cars uses the same motor (I don't care about the linkage, only need the cover off it).
To lost headlight motor cover help!
