oil change
Old Dec 21, 2009 | 06:35 PM
kuzmfly1's Avatar
kuzmfly1
Default oil change
Hello
How do you reset oil life % reading.
Old Dec 21, 2009 | 06:37 PM
Slow Z06's Avatar
Slow Z06
hold down reset button till it resets then turn off car and back on
Old Dec 21, 2009 | 06:40 PM
PCK1221's Avatar
PCK1221
Put the key in the ignition, turn it to the "on" position and "pump" the gas pedal 3 times.
Old Dec 21, 2009 | 06:43 PM
jrose7004's Avatar
jrose7004
Either of the above.
Old Dec 21, 2009 | 07:29 PM
kuzmfly1's Avatar
kuzmfly1
Old Dec 21, 2009 | 11:50 PM
rws.1's Avatar
rws.1
quickest way to reset.
Old Dec 22, 2009 | 12:22 PM
Procedure is contained in the owners manual if you have one. If not, you can download a copy from this web site: www.gmpartshouse.com.
Old Dec 22, 2009 | 05:22 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Old Dec 22, 2009 | 07:28 PM
Shanker's Avatar
Shanker
Cruising
The "pedal pump" procedure is the same for all newer GM vehicles. It's really convenient for do-it yourselfers like us.
To oil change
