Converting tail lights to 110v?
Old Dec 22, 2009 | 01:19 PM
MDR1970's Avatar
MDR1970
Default Converting tail lights to 110v?
Just purchased a rear clip that i want to hang on my garage wall. anyone done this? i would like to put in some 110v bulbs. any ideas?
Old Dec 22, 2009 | 01:25 PM
TraceZ's Avatar
TraceZ
My concern would be the heat given off melting the plastic lenses.
Perhaps some white 110v LED christmas lights would work and stay cool. You should be able to fit 2 or 3 bulbs in each lense to get the right brightness. Make sure your splices are done properly so you do not create a fire hazard.
Old Dec 22, 2009 | 01:32 PM
ALLEGRO's Avatar
ALLEGRO
Simple fix: go to Radio Shack, heck even Wal-Mart and pick up a wall adapter to run DC toys and electronics. Many of them are switchable and most all include a 12V setting. Just hook that baby up and you are good to go.
Just a suggestion, as mentioned in the above post (2), you might want to do the LED light thing to avoid heat.
Post some pics
Old Dec 22, 2009 | 02:22 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Post some pics
thinking the same thing - You can buy a 110 to 12 volt reducer/transformer and keep the lights for Auto's in there it will be safer and lower cost
Heck you could even use your battery charger
Thanks,Matt
Old Dec 22, 2009 | 02:40 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Member CULookin did it -
http://forums.corvetteforum.com/c5-g...s-of-pics.html
Old Dec 22, 2009 | 04:33 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I used a doorbell xfmr.
Old Dec 22, 2009 | 05:05 PM
srs244's Avatar
srs244
St. Jude Donor '09 thru '26
i had pretty much the same problem (but with an antique counter top jukebox selector unit). what i did was use a set of low power (step down transformer) lights i got at radio shack. originally power was supplied by the cable from the "master" or base unit of the jukebox, so this was a real simple solution to light it up and make it appear to be a working unit as opposed to a display piece. another alternative i would suggest would be to use a string of LED christmas lights that you can "group" into each of the tail lamp areas. they would provide plenty of illumination with a minimum (if any at all) of heat. i wouldn't think you would have to splice them at all.
To Converting tail lights to 110v?
