1 7/8th headers on a LS6?
Old Dec 22, 2009 | 06:40 PM
stock z06's Avatar
stock z06
Default 1 7/8th headers on a LS6?
will i loose any hp or tq?
any cons on running this size with only, cold air and tune?
will add a blower down the line (2 years or so)
ed
Old Dec 22, 2009 | 06:49 PM
DevilMan02's Avatar
DevilMan02
magic 8 ball says try again later
Old Dec 22, 2009 | 07:28 PM
Stevo92z28's Avatar
Stevo92z28
No cons.
The fastest Bolt-On C5Z runs them. I would say they work just fine.
Old Dec 22, 2009 | 07:48 PM
Corvette Don's Avatar
Corvette Don
Do 1 7/8, I wish I had as I plan to add some more cubes soon and I will have to buy new headers
Old Dec 22, 2009 | 08:27 PM
black98c5's Avatar
black98c5
Go for it! I wish I would of done it instead of going with 1 3/4", but I'll probably upgrade to the 1 7/8" next year.
Old Dec 22, 2009 | 09:26 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
unless you're FI, Big Cubes or a massive H/C, a smaller diamater primary will do you better for low end torque.
remember the smaller the diamater of the tube, the faster a given volume of air moves through the tub under a given pressure.
this does 2 things:
1) faster moving air creates a larger low pressure wake behind pulses that will pull gases from the other primaries at the collector
2) The less air you have in your exhaust system at any given time, the less effort the engine has to expend pushing the exhaust out. a larger diamater system will always have more exhaust gases in the tubes than a smaller one.
To maximize your performance you must match your performance components to eachother.
Old Dec 22, 2009 | 09:56 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
this does 2 things:
Old Dec 22, 2009 | 09:58 PM
MyOwn69's Avatar
MyOwn69
this does 2 things:
Well, I was gonna' tell you that if you're not going "big" any time soon, go with the "3/4" - but there's NO way I could have said it like that!
Old Dec 22, 2009 | 10:40 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I happen to have 1 7/8 AR with my blower setup and my little ole 347 puts down a mere 772 RWHP, so I would do the larger tube ones if you plan on a blower, seems to work well for me
Old Dec 24, 2009 | 01:48 PM
AntonioZ06's Avatar
AntonioZ06
damn, just when I start assembling my shopping list, things like this pop up and make me second think things.
I plan on staying 346 cubes (at least for now, lol), but am doing a full FAST 92/92 h/c over this winter. I was going to do 1 3/4, but now 1 7/8 is looking kinda nice. Any advice?
Old Dec 24, 2009 | 02:20 PM
blkdevl's Avatar
blkdevl
1 7/8 for the win
Old Dec 24, 2009 | 07:30 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
bernoulli's principle of fluid dynamics also applies to the intake. If you're looking for high peak numbers, your plan will work, but you'll sacrifice power at the bottom/mid range.
Old Dec 24, 2009 | 11:27 PM
sami85L98's Avatar
sami85L98
Just go ahead and do the 1 7/8 chief, bigger is smaller these days, wish i had buy 1 7/8 first.
To 1 7/8th headers on a LS6?
