Steering Wheel Lose
Old Dec 23, 2009 | 10:19 AM
BG04Z06's Avatar
BG04Z06
Default Steering Wheel Loose
I don't know exactly how to explain it but I bought a set of Bridgestone's about a month ago... had no problems... just had my car in the shop for brakes... then just in the shop again for headers/x-pipe install... now when I just picked it up notice that when I am cruising straight and the wheel is straight... when I go to turn left or right its very loose for like 1/2 inch turn right or left... so its driving me crazy because there is no feeling at that area. It also feels weird just holding the steering wheel as i keep shaking it back and forth and it moves very easily.
Wondering if anyone else knows what this is and how to fix it? I never had it until the latest shop visit.
Old Dec 23, 2009 | 11:18 AM
Indy's Avatar
Indy
...sounds like they messed something up in the shop...bring it back and complain about it. Indy
Old Dec 23, 2009 | 11:32 AM
Hard to say what it might be since it doesn't seem like the work that was done would have affected your steering wheel. I'd take it back in and ask them to have a look at it.
Old Dec 24, 2009 | 02:14 AM
memphis_vette's Avatar
memphis_vette
i have the same problem. it doesnt move a half inch mine moves about a 1/4 of an inch. my car drives perfectly straight its just that there is a little slack. annoying!
Old Dec 24, 2009 | 04:04 AM
Choreo's Avatar
Choreo
Check to make sure the Pinch Bolt is torqued to spec. If it is not tight you will get that delayed response or slop in the steering wheel. I have had the Dealership not tighten mine properly twice after removing the rack. If that is your problem it is an easy fix on the driver's side of the engine compartment from above.
Old Dec 24, 2009 | 07:54 AM
csexton's Avatar
csexton
Had the same problem after a steering position sensor was replaced and this fixed the play in the steering wheel.
Chuck
To Steering Wheel Lose
