Where can I buy some? I just bought some C6 wheels and have 3/8 spacers for the rear and am not getting enough lug nut contact. Where do most people buy them at? Thanks.
Try the dealer, or an auto shop, should be easy enough to get
Do you have to remove the hub altogether to get the old studs out and new ones in? Or is there an access hole or something that can be moved out of the way without removing the hub? Rear hub!!!
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Yes there is a certain spot you can turn the hub to, to remove the studs. If you search there are several post about it on the forum. The thing is you'll hear the argument of "is it safe" to do as it may cause stress on the bearing if you over hammer it. Some choose to disassemble and remove the entire hub. This is a lot more costly then doing it the easy way (if your not doing ti yourself).
On the rear it is not a question of just turning it to a certain spot- you have to drill a hole in the backing plate in a specific location and then plug the hole with a rubber groument when you are finished.
