Zune 2 Corvette??
Old Dec 27, 2009 | 07:28 PM
4DH8R's Avatar
4DH8R
Default Zune 2 Corvette??
As a self proclaimed apple hater (way too over priced), has anyone hooked up a Zune to their stock Bose head unit? If anyone knows where an install guide or adapters can be found please let me know.
Old Dec 27, 2009 | 07:49 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
aux2car or open the stereo and mod it to have an aux input
Old Dec 27, 2009 | 07:52 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Me too...lol
But I did get an Ipod nano...shame...lol
Old Dec 27, 2009 | 11:18 PM
saxtech's Avatar
saxtech
From: Huntington Beach / Fountain Valley California
Has anyone ever had an auxiliary input jack installed into the factory bose head unit - This would be so cool if it can be done.
Is there Anyone in Southern California that can do this without ruining my head unit ?
Old Dec 28, 2009 | 06:03 AM
Exoray's Avatar
Exoray
I will be doing this shortly, and yes it has been done... Most of the hacks I have seen (Google Search) interrupt the CD output, so the head unit thinks it's playing the CD, and thus you need a CD in the drive and be on the CD setting, you just block the CD output and inject the Mp3 players output instead...
I'm going to crack mine open and have a closer look, the CD hack is simple and definitely a DIY version, but I'm looking for a more elegant hack, possibly reworking the AUX button into functional and interrupting the line just before the amp or what not...
I design and build electronics professionally, so I have a one up on the average DIYer to take it one step further... As it stands I'll probably take a look at my head unit later this week...
Old Dec 28, 2009 | 11:21 AM
TakeAwayTheFear's Avatar
TakeAwayTheFear
apple haters...... there is no reason to hate. (typing from 24in. Imac) lol
Old Dec 28, 2009 | 02:45 PM
borkg2006's Avatar
borkg2006
I did the hack where you tap into the CD head with a post-jack. When you plug your MP3 cable into the jack it disconnects the CD head and completes a circuit with your MP3 player. You have to have a CD in the player and press the CD button on your radio. It wasn't that difficult but was time consuming. I probably have the threads, pics, etc. if you're up for this mod. You have to tear apart the dash and console, remove the radio, open it up and tap into it with a cable (CAT5 works well). This you run to the post-jack from Radio Shack that you can mount in the console box or, as I did, just under the ashtray.
Old Dec 28, 2009 | 03:27 PM
dbstephens's Avatar
dbstephens
I have installed a Zune 16GB HD Touch in my 2004 Z06. It required an interface box along with a special adapter harness to connect to the back of the existing control head. I used a cigarrette lighter-to-USB adapter/charger to power the unit while in the center console.
You select Aux on the control head and the interface simulates a CD changer connection on Disk 1 Track 1. Unfortunately, you have to control the funtions from the Zune itself, but the music is flawless.
Check the following links for the adapters:
http://pac-audio.com/productDetails....&CategoryID=24 (adapter box)
http://pac-audio.com/productDetails....&CategoryID=37 (adapter harness)
http://www.amazon.com/gp/product/B00..._ya_oh_product (Zune sync cable to attaqch to the plug-in 5VDC/USB converter)
http://www.amazon.com/Black-Mini-Cha...2031691&sr=1-7 (Plug-in Charger/USB adapter)
I had to drill a hole in the forward end of the center console to route the wires into the area. I simply lift the lid and select what playlist I want to hear and hit the road!
Don't leave the USB charger plugged in when the car is not in use. It will slowly drain the battery if you do. Have fun.
Old Dec 28, 2009 | 06:40 PM
Rich-L's Avatar
Rich-L
If you can make this work, please post or send me an message. I currently have an MP3 jack inplace of the CD Changer. I would like to be able to use the AUX and not the internal CD.
Thanks, Rich
Old Dec 28, 2009 | 10:40 PM
pentavolvo's Avatar
pentavolvo
in order to use the acutal aux button you need the aux2car, otherwise you do the hack on the internal cd player, super simple
Old Dec 29, 2009 | 12:26 AM
Exoray's Avatar
Exoray
My goal is to use the aux button without the aux2car adapter by doing an internal mod to the unit...
More of a challenge to see if I can do it then anything as the aux2car adapters certainly work and are for the most part painless...
If I can get it done for a few bucks, a little tinkering and reverse engineering the radio internals, I'll give it a go...
Old Dec 30, 2009 | 01:34 AM
GM Fan's Avatar
GM Fan
I have the Aux2car setup w/ the wiring harness adapter mentioned above w/ my 02 Z06, plugged right into the back of the factory radio (didn't have a CD changer). Works awesome IMO.
I went the DIY route w/ my previous 99 TA and did the mod to override the CD output w/ the factory radio. Same procedure as it would be w/ the Vettes I believe. Worked OK, but the little jack I got from radio shack wasn't the best quality. When I would plug in the audio cable from the Zune I usually had to wiggle/twist the cable a bit to get a solid connection otherwise I'd have static. Little annoying compared to the flawless operation of the aux2car setup.
Old Dec 30, 2009 | 03:18 AM
IM28702's Avatar
IM28702
+1 hating Apple. Good luck on your project.
Old Dec 30, 2009 | 06:58 AM
ILM-Express's Avatar
ILM-Express
MFIC
Old Dec 30, 2009 | 09:43 AM
ronjastone's Avatar
ronjastone
Old Dec 30, 2009 | 10:57 AM
Mike Mercury's Avatar
Mike Mercury
Yep; that is what I did for my 20bg Neo MP3 player (which I will be selling soon due to a head-unit upgrade).
front mounted control head:
main chassis in the same location as the Delco CD changer:
With this adapter - you don't have to take the radio out. But there is some minor expense involved. The PIE GM10-AUX adds a L/R Aux in; in-place of the factory external CD changer.
Granted, modifying the head unit with a switching jack is practically free (mostly all labor) - but R&R'ing the radio is not a 10 minute project.
Old Mar 24, 2010 | 09:26 PM
striped91's Avatar
striped91
http://www.ls1tech.com/forums/stereo...t-adapter.html
Did it last night. Sounds perfect!
To Zune 2 Corvette??
