[Z06] clutch questions
Old Dec 30, 2009 | 08:54 PM
obi05rp's Avatar
obi05rp
Default clutch questions
hey guys neeed some quik input on deciding on a clutch for my Z
just bout to rap up a 408 small block install huge cam
i was wondering what clutches would be best for streetability
i was thinking a spec 3+ but was told that might be a little rough on the start being a 6 puck i think?
quik stats on the build to give ya an idea of power etc
408ci
TF 235cc CNC heads
234/242 615/616 on a 111 LSA
and 100shot wet kit on top
headers etc
thanks guys need input pretty quickly
Old Dec 31, 2009 | 12:26 AM
USAFZ06's Avatar
USAFZ06
youre misinformed...spec 3+ is a full disk
Old Dec 31, 2009 | 12:39 AM
98turbls1's Avatar
98turbls1
I went with the Monster stage 4 with the billet stell flywheel. I'm doing all of my hydraulics and arp bolts while I'm in there. I'll let you know how it drives. It's a 6 puck setup.
Old Dec 31, 2009 | 04:38 AM
obi05rp's Avatar
obi05rp
yea thats why i came here cause i really dont know
iv heard its a good clutch to go with so hopefully u guys can help me decide
thanks
Old Dec 31, 2009 | 11:05 AM
USAFZ06's Avatar
USAFZ06
the spec3+ would be the minimum i would go...youre gonna make big power and big tq...look into a twin disk....RPS is the flavor of the month...i run a spec twin disk without issue its rated at 1395lbs of tq...not bad at all on the street...went 10s with my na 346 z06 the other day slipping it from a 4000 launch....it has a very short engagement window making it tough to slip at the track but it's doable...this spec twin WILL hold there are lots out there with broken parts to prove this
stay away from textralia
if you go monster...do minimum level 5 at your power output...monsters soon coming out with a twin you may want to look into
Old Dec 31, 2009 | 11:06 AM
USAFZ06's Avatar
USAFZ06
obi05rp just noticed youre in wilmington...im in goldsboro
Old Dec 31, 2009 | 11:07 AM
USAFZ06's Avatar
USAFZ06
ok reread your post...youre looking for streetability? is this a street car? going to the track? if its a street car you have no need for a 100 shot unless you just like spinning tires. On motor and on the street a LS7 clutch will meet your needs...but not at the track nor the 100 shot...all gonna come down to is give and take streetability vs holding power vs what youre gonna use the car for
Old Jan 6, 2010 | 01:31 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
ACT twin - ACT TWIN - Click Here
Stock feel - no weird *** heavy pedal
Smooth engagement - not a pain in the **** in traffic
Holds Torque- up to 1450 lb ft!
I know of no other clutch made that meets the above criteria and is this affordable. My recommendation is not based on a "smoking deal" or "buy it because I have one testimonial" I recommended ACT because we've track tested it for over a year and it does not fail - and, more importantly, they stand behind the product and that makes both the seller and the customer happy. Win-Win
ACT is a real manufacturer with 100%, in-house manufacturing facility complete with heat treating and produces what may well be the finest Corvette clutches on the planet.
408ci
TF 235cc CNC heads
headers etc
Old Jan 6, 2010 | 01:36 AM
obi05rp's Avatar
obi05rp
the car is going to be a street car, and see some track time
i ended up going with the spec 3+
im going with a progressive timer on the nitrous so it will be kicked mid rpm and knocked off before redline, doubt i will be spraying anytime soon since i have to break the motor in and well its been cold as **** out lately
car shuld be done thursday i appreciate all your feedback
and yes i am down in wilmington
To clutch questions
