I was thinking about purchasing the red Z06 calipers. Are there any differences between the the Z06 and the ones on my 00 vert ? Or should I just paint mine red and save the the difference to spend on another mod. They run about 400.00 from what I can see.
Thanks,
Jeff
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
They are the same, Only color is different, I painted mine because I am lazy and they turned out real well, I used the Duplicolor Caliper paint and are holding up really well, One thing I would do it thin out the paint a bit, It is really thick and make sure you trep them well.
Mr.Bill
I painted mine with a VHT rattle can I got at AutoZone. Mask off the area really well. Clean the calipers with thinner. Spray several light coats of paint until covered. Clean off the letters with a old t-shirt streched over your index finger dipped in thinner. I did mine over 2 years ago and they still look great!
