Help an old man out please!
If you remember back, my father had problems with his blinkers and such. The consensus was that he needed the hyper flash thing, and we bought it and installed it.
The blinker stopped blinking twice as fast as normal which lead me to believe the problem was solved, but actually, it's not....
What is happening now is that both rear lights blink (on each side) instead of just one at a time, meaning if you turn the right signal on, both rights blink instead of just the outside one as normal and vice versa with the left, and none of the fronts blink at all. The do come on as running lights when the head lights come on, but they do not blink.
I thought that it might have been the hyper flash bypass thing so I purchased another from a separate manufacturer, and had the exact same results.
I really could use some help, as I really don't want my father having to spend a fortune on electrical diagnostics.
PLEASE!
The fronts might have burned out bulbs....
