Looking at a 98 C5
I found a 98 Vette at the low price of 15K. 15K might not sound cheap for you guys but up here the prices for Vettes are crazy high.
So anyways, its a 98 auto. What are the possible problems to look for typical on early C5's? I guess that it being the second year of the generation there are probably some bugs. How reliable are early C5's? Do they breakdown often and what are frequent repairs on these vehicles? Any advice is appreciated.
Ive owned 3 Vettes in the past and right now own a 93 Z28 and I do work in the auto industry but I dont know too much about C5's.
You can look at the "sticky" at the top of the home page....Weights, measurements, ratios, strengths, etc. Explains all the possible probs.
Don't let that scare you off.
Nobody has all those probs. on one car!
Is the one you found $15,000 Canadian? If so that's an amazing price!! How many km on it? What color and options does it have on it? Did you find it in Quebec?
but thats a coman thing on the C5 run and gun after that
I waiting for a response and will post more details if seller answers me.
I have a '98 that has had the following things done to it during the first 80,000 miles...it has been trouble free since. ( I bought the car with 85,000 miles and it was totally bone stock..it now has 100k miles):
Battery leaked...zero damage to wires/components
however req'd vacuum hose/vent valve thingy replacement
Fuel tank senders (was done under warranty)
Dim dual zone display (was done under warranty)
Column Lock (recall done under warranty, I've added CLB)
Rear Wheel Bearing
harmonic Balancer
plastic end links replaced
spark plugs
clutch/pp (I've heard most auto vette trannies get tired at 100k)
A/C required a charge
Oil Pressure sender
and that would be it.
From what I understand, these are very common issues...
In every other regard, the car has been good to me, runs very strong and shows no signs of mechanical issues- even at 160,000kms.
HTH,
TG
My black car has 73K miles on it. I have replaced the following:
1. Front wheel bearing
2. All four tire pressure sensors
3. All three sets of hydraulic struts (hood, tonneau cover and trunk)
4. Oil pressure sending unit
5. Coolant recovery tank
6. Brake Master cylinder reservoir
7. Power antenna
8. headlight gears
My other '98 is a low mileage pace car and has needed nothing other than routine maintenance.
The only problems that we have had with any of our C5's in the past 8 years were:
Wife's '00 Vert:
Replaced headlight module.
Replaced one headlight gear.
'98 Coupe:
Broken H-pipe flange welds- cat back side, both sides.
'98 Vert:
Column locked, got it free and installed a CLB.
Bad headlight switch, replaced the stalk.
My street rod coupe was the same way, If I let it sit it would start having problemsbut when i took it out an ran it hard It loved me
soft hearted Dave
