Explain Sway Bars please:)
Old Jan 11, 2010 | 03:07 PM
Dominic Toretto's Avatar
Dominic Toretto
Default Explain Sway Bars please:)
Basically I want to know why certain sway bars are "better" and why some of you chose what you did. I am not too familiar with this part. However I do know that the effectiveness of the sway bar has to do with the weight of it, thickness, material, etc. So for those that chose to go with a C5Z, C6Z, or aftermarket sway bar setup, why, and what changes were observed? Thanks guys
-Alex
Old Jan 11, 2010 | 03:15 PM
Vega$Vette's Avatar
Vega$Vette
-Alex
They are really anti-sway bars. They tie the front wheels together so when the outside wheel goes up in a turn it applies force on the inside wheel to keep the car flatter in a turn.
The heavier/stiffer the bar the flatter the ride (and also stiffer) so you have to use a bar that is a compromise between anti-roll and stiff ride.
Old Jan 11, 2010 | 03:16 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
not to oversimplify the answer, but what it does is stiffen the ride and keep the car more level when cornering. basically the differences pretty much come down to the amount of stiffness you desire. the thicker and heavier the sway bar the stiffer it will be. please keep in mind this explanation is an extremely simplified one.
Old Jan 11, 2010 | 03:17 PM
roscoe118's Avatar
roscoe118
By no means an expert, Alex, but as I understand it, the larger (diameter) the sway bar, the less body roll you will have. Thats pretty obvious, but the caveat is the width of the tires. Less body roll isn't necessarily a good thing with narrower tires. With less rubber on the road, they are more apt to break free, with less body roll. And of course the shocks also have a say in how much "roll" occurs, so that is why some shock/sways are "tuned" together for certain cars, knowing the size of the tires on those cars.
Of course, I could be completely out in left field!!!
Just put '04 Z06 shocks and sway bars on my '02 Coupe, and I love it. It now feels like a real sports car. It had the FE1 suspension, and that was way to "floaty" (for lack of a better term).
Old Jan 11, 2010 | 03:27 PM
Indy's Avatar
Indy
In essence, a sway bar connects the left and right suspension to improve handling. I disconnect the front sway bar on my Jeep all the time for offroading for better flex, but road handling definitely suffers when disconnected. For ultimate performance, a thicker sway bar (less flex) would be better (like the Z06) - less body role.
Old Jan 11, 2010 | 03:37 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Think of it as a torsion bar because torsion bars (suspensions) twist the bar to achieve spring flex.
The anti-sway bar is anchored to the frame in the middle and both wheels flex or twist the bar against each other in turns.
Wikipedia starts like this:
"A sway bar (also stabilizer bar, anti-sway bar, roll bar, or anti-roll bar, ARB) is an automobile suspension device. It connects opposite (left/right) wheels together through short lever arms linked by a torsion spring. A sway bar increases the suspension's roll stiffness—its resistance to roll in turns, independent of its spring rate in the vertical direction"
I had an old '79 Honda Accord with a stock front bar only...very thin. I added a 1" Quickor brand bar to the front and a 7/8" bar to the rear.....holy moly....what a great difference! I always said it cornered like a pancake...FLAT! Then I installed shorter, stiffer springs.....very nice without compromising ride quality.
Old Jan 11, 2010 | 03:42 PM
Uncle John's Avatar
Uncle John
Also, bear in mind that when folks talk about the ride being stiffer, they are referring to the ride while in a turn or hitting bumps with one wheel at a time. Anti-sway bars have almost zero effect when traveling in a straight line since the wheels on both sides of the car will be going up and down together.
Old Jan 11, 2010 | 03:45 PM
Dominic Toretto
Thanks guys! Any idea of how much beefier the ZO6 bar would be against the stock one?
-Alex
Old Jan 11, 2010 | 03:46 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Good info. I learned something too
Old Jan 11, 2010 | 03:50 PM
PartsTaxi.com's Avatar
0PartsTaxi.com
Former Vendor
See if this helps.
Old Jan 11, 2010 | 04:40 PM
Atok's Avatar
Atok
Rather than typing it all again, here is a response I posted to another thread:
http://forums.corvetteforum.com/1572670031-post21.html
Old Jan 11, 2010 | 04:48 PM
tail_lights's Avatar
tail_lights
Cool info!
Old Jan 11, 2010 | 05:53 PM
Vega$Vette's Avatar
Vega$Vette
-Alex
Stock on top ZO6 on the Bottom
Rears
Old Jan 11, 2010 | 06:01 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Very good explanations . That's one of the first mods I did, fatten up the front/rear sways.
Old Jan 11, 2010 | 06:07 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
All above is correct. Only thing I will add is it is possible to take this concept too far. The result is you no longer have independent suspension, so a delicate balance is required by engineering vehicle tests. Again, this is way oversimplified but is well known in the automotive industry by chassis engineers.
Old Jan 11, 2010 | 06:11 PM
AntsSilverC5's Avatar
AntsSilverC5
Not to jack the thread but while we are on sway bars, what would be a good combo sway bar for upgraded hotchkis shocks? Other than the shocks, my only "handling" upgrade is my 19" CCWs with 275 30 fronts and 305 30 back yokohamas. What sway bars would you guys recommend?
Old Jan 11, 2010 | 06:13 PM
Vega$Vette's Avatar
Vega$Vette
They come stock with sway bars and independent suspension.
HaHa! You are right that bigger and stiffer is not always better. (for a car that is)
To Explain Sway Bars please:)
Old Jan 11, 2010 | 07:32 PM
vette.mix's Avatar
vette.mix
me too
Old Jan 11, 2010 | 08:34 PM
Swt_86's Avatar
Swt_86
I installed the C6Z51 bars on mine last fall and would HIGHLY recommend them to anyone thinking about upgrading the standard C5 suspension. The upgrade was low cost, an easy install and greatly improved the way the car feels in a corner. They reduced body roll with a minimal negative impact on the ride quality.
Old Jan 11, 2010 | 08:41 PM
redrckt97's Avatar
redrckt97
one more factor on sway bars Alex -- its important to have the right balance between front and rear bars -- the end with the greatest roll resistance (stiffness) will slide First in a hard corner - so too big of a bar on one end (like putting a C6Z06 bars on a C5 without the much larger rear tires of a Z) can make it oversteer or understeer badly.
