what do i do?
Old Jan 16, 2010 | 02:33 PM
ssidekickbp's Avatar
ssidekickbp
Default what do i do?
This may seem stupid, but when I first got my car about a year ago I never had the steering wheel shake while driving fast. Well, I had to loosen the bolt that holds the steering wheel in order to lower it to get my aluminum bezels on for the gauges. I tightened it back up but now when i get to 60 or so the wheel shakes. My questions are
1- Do I need to tighten or loosen this more?
2- at what speed are you supposed to have this shake happen? is it normal?
3- any help would greatly be appreciated
Old Jan 16, 2010 | 02:35 PM
KOZ's Avatar
KOZ
Wheel shake is usually attributed to wheel balance....I'd have my wheels/tires balanced.
Old Jan 16, 2010 | 02:37 PM
ssidekickbp
come to think of it, it got worse after i had my whole brake system re-done. could that be it, I know that they had all 4 wheels off the car?
Old Jan 16, 2010 | 02:59 PM
4theboy's Avatar
4theboy
Shouldn't make a difference unless they knocked a balancing weight off in the process. To start I would have the front tires checked and have all 4 balanced and see how it works.
Old Jan 16, 2010 | 03:09 PM
billyj's Avatar
billyj
always check your lug-nuts.
Old Jan 16, 2010 | 03:51 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The lug nuts should be torqued to 100 lb. ft. You should also consider a road force balance - but the burning question is what condition are your tires? Are they unevenly worn?
You've had the car 1 year - but how many miles are on tires?
If you are ready for new tires, just make sure that after you make purchase - that the lug nuts are properly tightened in a star pattern to 100 lb. ft., that the tires and wheels are road force balanced, and your shake should go away.
Old Jan 16, 2010 | 03:53 PM
ssidekickbp
Thanks guys, I made an appointment monday morning to have it all checked out. I was so worried I screwed something up.
Old Jan 16, 2010 | 03:55 PM
tremor1's Avatar
tremor1
What is a "Road Force Balance"?
Old Jan 16, 2010 | 04:54 PM
blacksedan87
I believe that there are other companies out there, other than Hunter that manufacture machines for road force balancing, Hunter is the most well known.
Here's a link to their site that explains the process and the benefits....
http://www.gsp9700.com/pub/features/how.cfm
Old Jan 16, 2010 | 05:19 PM
The steering wheel should not be shaking - if the nuts holding it in place are loose, tighten them up. Otherwise, I agree that usually it is a symptom of wheels out of balance. That may be something you need to get checked too.
Old Jan 16, 2010 | 06:42 PM
Stevo92z28's Avatar
Stevo92z28
You said you had to loosen the "bolt" that holds the steering wheel? Do you mean the 2 bolts that hold up the column?
Old Jan 16, 2010 | 06:45 PM
ssidekickbp
yeah, at it's base, but I tightened them back up. I honestly didnt notice the shaking till after I had the brakes done. Thats the only time all 4 wheels have been off the car.
Old Jan 17, 2010 | 08:26 AM
japc5's Avatar
japc5
I agree with others that you should have your wheel balance checks. Since you said it is worse since you have you brakes worked on I would check the tire rotation to be sure they placed the wheels back on the correct side of the car. Swapping left/right, right/left could cause this symptom.
Old Jan 17, 2010 | 09:05 AM
rws.1's Avatar
rws.1
that will not cause shaking... out of balance wheel/tires/ or worn suspension parts will
Old Jan 17, 2010 | 10:56 AM
ssidekickbp
thanks guys, I will let you know the outcome tomorrow, It's great to have the knowledge on here. I have always been helped from this forum.
Old Jan 17, 2010 | 11:01 AM
tremor1's Avatar
tremor1
Interesting. Thanks
Old Jan 20, 2010 | 09:41 PM
ssidekickbp
Thanks for all the help guys. I found out they did have to be balanced. only charged me 15 bucks too! And my front passenger rim is slightly bent. I planned on getting new ones come spring anyways, so I guess that was it. The shaking is gone though. Thanks to everyone who gave their input!
To what do i do?
