oil filter
Old Jan 16, 2010 | 11:19 PM
c5walt's Avatar
c5walt
Default oil filter
I will be doing my first oil change shortly. I see alot of people praising Wix filters. Any recommendations?
Old Jan 16, 2010 | 11:21 PM
jrose7004's Avatar
jrose7004
I use that K&N oil filter.
Old Jan 16, 2010 | 11:25 PM
c5walt's Avatar
c5walt
Thanx. K&N was my first thought.
Old Jan 16, 2010 | 11:40 PM
I've always used AC Delco filters - they work well for me. Mobil 1 makes good filters too.
Old Jan 16, 2010 | 11:51 PM
jrprich's Avatar
jrprich
WIX makes great filters
Old Jan 17, 2010 | 12:21 AM
Bill Vett's Avatar
Bill Vett
Wix or NAPA Gold
Old Jan 17, 2010 | 03:46 AM
SJPD's Avatar
SJPD
which is the exact same as a mobil 1 filter except for paint , price and the welded nut
Old Jan 17, 2010 | 05:22 AM
JerG's Avatar
JerG
I was using Mobil 1 but just had oil changed this week and they did not have this one, so
I switched to K & N, did not know they're the same inside. Oil filters are like batteries,
a few makers making a bunch of licensed and private label brands. WIX, I hear is a good
one.
Jerry
Old Jan 17, 2010 | 06:45 AM
Baron138's Avatar
Baron138
I use K&N or Mobil 1. Happy with both.
Old Jan 17, 2010 | 06:56 AM
LoneStarFRC's Avatar
LoneStarFRC
Yes. 51042
Old Jan 17, 2010 | 07:52 AM
Oldvetter's Avatar
Oldvetter
I used DELCO Premium UPF-44, then read here that they were restrictive. I changed to a WIX (same as NAPA GOLD) and my cold oil pressure increased 10-15 psi. Since the C5 oil pressure sensor is AFTER the oil filter, more pressure means more flow.
ET, an ex-GM C5 Engineer, said that the standard GM filter is all you need. GM did a 200,000 mile run using them.
I have seen where some people have scrapped a K&N filter, since the nut hangs down. It doesn't seem like you would want your oil filter to be the lowest point of your car, IMHO.
Old Jan 17, 2010 | 09:12 AM
rws.1's Avatar
rws.1
Mobil 1, K&N, AC/Delco, Wix, Napa Gold are all good.
So are Baldwin and Purolator PureOne.
But they are divided into two camps...that tend to be mutually exclusive...
those that flow better
those that filter better
You need to decide which you want.
I am almost positive that Mobil 1 and K&N are not identical inside...they may look similar but the filter media is different...The K&N is made to flow... The Mobil 1 is made to filter.
Old Jan 17, 2010 | 09:22 AM
2003 electronblue's Avatar
2003 electronblue
they did a study on all the filters by cutting them in half and looking at the filter it was clear that there all different inside and the best one was the mobile one with the ac delco second. but i use a fram because thats what walmart gives me!!
Old Jan 17, 2010 | 09:26 AM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
AC Delco.
Old Jan 17, 2010 | 09:39 AM
dooscoop32's Avatar
dooscoop32
I agree 100%. Those are the only two I have used on any of my Corvettes.
Old Jan 17, 2010 | 09:51 AM
billyj's Avatar
billyj
i will be using mobil one, oil & filter!!!
Old Jan 17, 2010 | 10:23 AM
2_99_c5s's Avatar
2_99_c5s
I use Mobil 1 Extended Performance
To oil filter
Old Jan 17, 2010 | 10:51 AM
Patman's Avatar
Patman
Honestly, when it comes to oil filters there are more good choices out there than bad ones, it all depends on how much you want to spend, and availability in your area. I'd have no problem running any of these filters (and have indeed used almost all of them in different cars over the years):
Wix
NAPA Gold
Carquest Premium
Purolator
Fram Extended Guard (this is what I'm using, it's much different than the cheaper Frams)
Mobil 1
K&N
AC Delco
Supertech (sold at Walmart only)
STP
Amsoil
Pennzoil (same as Purolator Classic)
Quaker State (also same as Purolator Classic)
Old Jan 17, 2010 | 12:09 PM
hattitude's Avatar
hattitude
Originally Posted by Bill Vett
Wix or NAPA Gold
They are both made by Wix .....
I use them on my cars and the Wix or Baldwin filters on the diesel engines in my boat.
Old Jan 17, 2010 | 01:06 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
