Lately I have noticed when I drive at night, occassionally the headlights will dim slightly, and then brighten up again. I also notice when it does this, the volt gauge drops about 1/2 volt and then goes back to normal. In the 12 mile drive from work to home, it happens maybe a half dozen times, and it doesn't seem to matter if I'm on a straight stretch of road or in a turn. Also going from smooth road to bumpy doesn't seem to make any difference. Bad alternator maybe? Or a ground problem? Anyone else have a similar issue?
Give this a looksee. Both pos/neg cables are easy to trace to check for a break in the wires. Also check the grounds behind both headlights on the frame rails.
