CyberdineGraphics decal help needed...
Old Jan 17, 2010 | 12:29 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Default CyberdineGraphics decal help needed...
If someone has installed one of these I need to know if there were any special instructions. I picked one up from my forum buddy Yanni for my interior upgrade. There is a link for installation instructions on the package, but the link is dead (cyberdinegraphics.com/corvette_c5.html). I just want to be sure there are no unusual steps before I install it. It is to go on the center console lid that I covered with alcantara. There is a slight curve to the surface and I want to insure the tips of the C5 emblem do not pop up....
Old Jan 17, 2010 | 12:43 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Here you go buddy, It is cake to install, Just make sure you clean the surface really good first.
Mr.Bill
Link works for me.
http://www.cyberdinegraphics.com/corvette_c5.html
Old Jan 17, 2010 | 12:58 PM
Hammer99's Avatar
Hammer99
For a cleaner I used denatured alcohol. Dries fast.
Old Jan 17, 2010 | 12:59 PM
Mr.Bill's Avatar
Mr.Bill
That is what I used also.
Old Jan 17, 2010 | 02:21 PM
$$$frumnuttin'
thanks guys I must have mistyped the linky...wouldn't be the first time
Old Jan 17, 2010 | 02:29 PM
jrose7004's Avatar
jrose7004
I use tweezers and rubber gloves too.
Old Jan 17, 2010 | 10:41 PM
olbear1962's Avatar
olbear1962
Old Jan 17, 2010 | 11:07 PM
ALLEGRO's Avatar
ALLEGRO
Clean surface. De-natured alcohol.
ENJOY
Old Jan 17, 2010 | 11:25 PM
JETZ's Avatar
JETZ
''It is to go on the center console lid that I covered with alcantara.''
Don't think it will stay on a porous surface!
Old Jan 17, 2010 | 11:44 PM
yaknow's Avatar
yaknow
I used the wifes scrapbooking tweezers, long tips and easy to operate
Old Jan 18, 2010 | 11:34 AM
$$$frumnuttin'
I will find out....I am bringing the console lid indoors where the humidity is low and it is 70 degrees, like they recommended for conditions. Also, I will add a few drops of glue at the tips etc to insure adhesion...also I plan to put a couple books on it overnight and pray for the best!
Old Jan 18, 2010 | 11:48 AM
Dominic Toretto's Avatar
Dominic Toretto
Will 97% alcohol work the same? Not sure if that is denatured but, that is what I keep.
-Alex
Old Jan 18, 2010 | 11:56 AM
$$$frumnuttin'
-Alex
Yes, no problem...will evaporate faster than solutions with more water in them...just be sure to wait til it is perfectly dry.
Old Jan 18, 2010 | 09:16 PM
$$$frumnuttin'
Default Done...
Turned out perfect...tips stayed down...I guess this proves it will stick to alcantara, even if it is perforated. Kept in front of the fireplace where the air is warm and dry.
Old Jan 18, 2010 | 10:00 PM
Looks awesome - best of luck with the decal staying in place.
Old Jan 18, 2010 | 10:18 PM
JETZ's Avatar
JETZ
Well I hope it does stay on for you, but summer heat is coming.
My worry is that the bottom of the 'flag staff's' will curl, and break off.
Keep your fingers crossed.
To CyberdineGraphics decal help needed...
