visor question.
Old Jan 17, 2010 | 01:22 PM
ssidekickbp's Avatar
ssidekickbp
Default visor question.
when I first got the car, on the passenger side someone had tried to remove the label, but theres a little left of it. and the driver side one is still on.
My question is has anyone used anything to get these off complete? and if so with what? I really don't want to have to order those covers for them. Thanks!
Old Jan 20, 2010 | 05:53 PM
craig04c5's Avatar
craig04c5
I tried to get my passenger side off and while it did come completely off it left the area with little pills or roughness. I did not like that so I wound up getting the "Corvette" sticker. I think it looks better then the warning label and the roughed up area I created. I replaced the drivers side visor with one that has the garage door opener buttons in it and no label so that side was not an issue.
Old Jan 20, 2010 | 05:56 PM
jrose7004's Avatar
jrose7004
Try to peal the rest of it off by using a hair dryer to heat it up, I had no problem removing mine completely.
Old Jan 20, 2010 | 06:34 PM
Jet-Jock's Avatar
Jet-Jock
I put a little 3M Adhesive remover on a rag and it removed nearly all the residue. Mine were removed when I got it nearly new so someone took mine off. Then I had to replace the drivers and now it had the label. I removed it!
Probably GooGone on a rag would work too.
To visor question.
