crappy Russell adapter
Old Jan 18, 2010 | 11:05 AM
Padler's Avatar
Padler
Default crappy Russell adapter
Per this "closed" link, I am having the exact same concerns...
http://forums.corvetteforum.com/c5-f...ct-danger.html
I have -6AN stainless fuel line in my engine compartment & need a fitting/connector/adapter to hook the GM Snap-Lock hardline coming from the fuel tank/pump into the engine bay to my stainless line. Currently using the Russell 640850 and have it reinforced so it won't come off under pressure using special silicone tape that's impervious to fuel. It's a crappy way of doing it but the Russell connector is so flimsy, I'm aftaid it'll pop off and spill fuel onto my hot exhaust.
Per the attached thread, I contacted DTE thinking they could help (and I am a previous DTE customer) only to be told, "We no longer manufacture or deal in any engine performance parts, sorry." No suggestions, recommendations, etc. even though their response in the post seems that they are there to help in this serious situation that can cause your beloved car to literally go up in smoke.
DOES ANYONE MAKE A GOOD QUALITY CONNECTOR TO HOOK THE STOCK FUEL HARDLINE TO A -6AN LINE SIMILAR TO THE RUSSELL 640850? Thanks!
Old Jan 18, 2010 | 01:09 PM
densz06's Avatar
densz06
Cruising
Active Streak: 90 Days
i had same problem using there fuel line adapter,it,s not the fitting but the clip inside of it that stopping it from clipping on to the hard line.i work for a chrysler dealership as a tech we use this style connector on are fuel filters.you can buy them at a parts store or go to a dealer and ask a tech if has some lying around. its the plastic clip inside.
Old Jan 18, 2010 | 04:12 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
After I had one of these very same adapters separate on me and spill fuel on my hot exhaust (which started a fire), I contacted Russell and was told to go pound sand by one of their corporate lawyers. Hopefully Russell falls off the face of the Earth in the near future, because they don't give a flying fu#*k about their customers.
Old Jan 18, 2010 | 07:30 PM
ssmith512's Avatar
ssmith512
Dorman makes the fitting. Summit Racing carries them. Supposedly superior to the Russell fitting. I myself am going to try and braze an AN bung on the hard line on the car. Dont really need a QD. I dont plan on removing the fuel line all that often.
Old Jan 19, 2010 | 12:37 PM
Padler's Avatar
Padler
Default ordered part(s)
Thanks for the input, guys! Yeah, I can't believe Russell would sell a part so flimsy that handles fuel!
Anyway, I ordered both the plastic replacement clips (set of 5) as well as the steel (stock style) clips from Amazon....see which works better (plastic or steel). Went to Summit Racing but they're currently out-of-stock on these Dorman items.
To crappy Russell adapter
