popping
Old Jan 19, 2010 | 10:01 AM
davezo6's Avatar
davezo6
6th Gear
Default popping
my 2002 zo6 is having hard time going into reverse it seems like it is grinding until i play with it then she finaly goes into gear please help with some knowledge of whats happening thanks dave
Old Jan 19, 2010 | 10:42 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Always start with doing a shifter alignment. Its easy and fast to do. Past that, sounds like some synchros are about done.
Old Jan 19, 2010 | 05:52 PM
LoudassZ's Avatar
LoudassZ
St. Jude Donor '10
Synchros... same thing happened to me. It got so bad I couldn't go into 3rd and 4th
Old Jan 20, 2010 | 01:34 AM
tricep's Avatar
tricep
St. Jude Donor '09
Gotta love em.. another one of those little things I tend to forget about in my everyday "grind"
Old Jan 20, 2010 | 01:50 AM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Also have to wonder if your clutch is fully disengaging while trying to find Reverse or any gear. Could be low clutch fluid (check the reservoir) or a needed adjustment ( is there an adjustment? I dunno).
Or....between trying to change gears...try letting the clutch out to slow down planetary gears (could be talking out me **** here) in order to help the gears mesh. (like double clutching in some cars)
I'm speaking from usual car experience but not necessarily for our Corvettes as I have yet to gain much experience working on my 'o2.
Please,....somebody with more knowledge tell me if I'm off course so I can learn too.
Worn synchro rings is also a good call....
Old Jan 20, 2010 | 02:12 AM
Blown 346's Avatar
Blown 346
I sometimes have this issue. I normally put the car in 5th or 6th first then reverse and dont have the problem.
To popping
